Question about Craftsman Garden
Craftsman 28cc gas weedeater gas line connections
The fuel lines in my craftsman 28cc gas weedeater have 'disintegrated'. I removed them without noting which lines go where - there a 2 holes in the fuel tank, a primer pump and (of course) 2 carb outlets.
Anyone know the proper connections or have pics of the lines connected ?
  • backhoe_1 Jul 06, 2009
    this is a 1993 Craftsman weedeater with a Zama
    Carburato - model number C216.51315. There are 2 outlets on the carburator, 2 on the primer pump and 2 in the gas tank.
    Thanks
  • 1,041 Answers
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 04, 2009
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
Why does the fuel not stay in the primer bulb, when I prime the craftsman weedeater with sim-pul
Fuel lines probably need replacing. Have you been using ethanol? The alcohol eats the fuel lines on most 2 cycle motors up.
Jul 06, 2014 | Craftsman Convertible 25cc. Gas Line...
Weedeater blower will not stay running
how long will it run? 30 seconds 10 min.
pour ot the gas & look inside the fuel tank is it dirty?
is the filter still hooked up to the supply line. Mine had fallen off [worn out] I replaced with new fuel lines and still had a 20 sec run. It was flooding let me know
Sep 02, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
Fuel line on husqvarna weedeater need replaced
They are just a pull/push fit. The fuel line has 2 flanges that should fit either side on the fuel tank. Pretty simple to replace.
May 12, 2012 | Husqvarna 28cc Gas Line Trimmer
I am not getting gas to my weedeater
Well, all the fuel delivery starts with the fuel filter in the fuel tank..so check that and then check the condition of the fuel lines, and then remove the covers from the carb (the one without the hole in the cover), Check inside the carb for a very small round fine mesh screen. Make sure it is clean...if not ..clean it with non-flammable brake cleaner. If it has debris on it, then it is restricting fuel flow thru the carb. Does the spark plug ever smell like gas at all. Is the primer bulb pulling any gas at all to the carb thru the small diameter fuel line? Check around and post back if you like.
Aug 15, 2010 | Craftsman 25cc Gas Line Trimmer
Does the black gas line onmy weedeater connect to the (fuel filter?) in the gas tank?
Yes the fuel line on the 125l is an assembly that the fuel filter is attached to. If it is not it may still run but you are not filtering your fuel and any impurities could damage your carb and possibly your cylinder wall.
Jun 09, 2010 | Husqvarna 28cc Gas Line Trimmer
Craftsman 25 cc weedeater keeps shuting off, was running fine
Probably fuel line into tank has hole in it, If over 5 years old these fuel lines become brittle and break easy. Go to local hardware or repair shop that has small engine parts and you should find the fuel lines. Be sure to take sample with you as there are many sizes. If you have trouble installing them get back to me. Be sure you know how the lines are routed before removing.
Apr 05, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
1,281 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
