Question about Canon PowerShot S410 / IXUS 430 Digital Camera
Locked Memory crad
It says memory card locked but its not and I bought a new card
    Problem Solver:
  • 3 Answers
If you look on the side of the memory card, there is a little slider thing that locks it. If it is pushed up, slide it down or vice versa, that should unlock it. I think that it's a safety feature so that you can't delete photos accidently. I hope that this helps :)
Posted on Jun 30, 2009
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
I bought two new 8GB SDHC memory cards for my canon ixus500. the old memory card is 1GB ad still works but i wanted more memory cards. neither of the two new cards work. they both say memory card error AND...
If your camera is the type that uses SD cards, then your problem is that the camera was developed in 2004 before SDHC cards were invented. Your camera cannot use them.
Sep 15, 2011 | Canon PowerShot S500 IXUS 500 Digital...
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
May 08, 2010 | Canon PowerShot A450 Digital Camera
"Card Locked"
Hi!
There's a small switch on the memory card reader inside the camera which detects that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Tom
Sep 23, 2009 | Canon PowerShot A590 IS Digital Camera
HP Photosmart R967 memory card is locked...
I have an HP R927 and just had the same problem. Take out your memory card. Look on the side of the card and you will see and white "knobby thing" ... make sure it is pushed up ... that should fix it.
Sep 12, 2009 | HP Photosmart R927 Digital Camera
Memory card error
Did you format the card in the camera before trying to use it?
Sep 02, 2009 | Canon PowerShot A700 Digital Camera
New San Disk memory card not working
vebhat,
Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera...
randy320sgi
Jan 09, 2009 | Canon PowerShot SD600 Digital Camera
New Card Locked
Have you tried to format it with the camera? It may need formatting in order to unlock it.
May 10, 2008 | SanDisk 2GB Secure Digital Memory Card
Memory Card Locked
There is an option to lock the memory card, so here's what you do. Open battery slot<remove card<there is a lock tab just switch it to unlock. tab is on side of card on SD card
Dec 08, 2007 | Samsung Digimax D53 Digital Camera
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
73 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
