1999 beetle AC... Ac works maybe 1 in 10 times for about 10 minutes then stops. Checked 134a level (good)... When AC is turned on, aux fan turns on, clutch engages on compressor and 134a pressure drops slightly, but not to normal operating range. When the few times it works, 134a pressure drops to normal range.
    President:
  • 3,433 Answers
System is short cycling. A sign of low refrigerant. Post the numbers you get from the gauges for me if you would. Two readings. One at idle and the second at around 1200 rpm.
Thanks -Ned
Posted on Jul 11, 2013
  • 6,927 Answers
Check ac and let car get hot(not overheated) and with guages on high side is it above normal? 2.75-300 or more? this would be the problem ac cutting out cause ther is a problem some where u need to use ac gauges it will tell the story
Posted on Jul 01, 2009
My 1999 mazda 626 6 cylinder overheats if traffic slows down for very long, stop for a train, etc. At other times the air coming out of the vents is very cold. I have added coolant several times.
Your radiator fan is probably failed. Pop open hood, watch temp rise, once past "normal " level teh fan should turn on. If not, you need to trouble shoot the rad fan. There should be heavy duty fuses and relays under the hood in an electrical distribution box. You should consult the owners manual or chart on the box lid. Of course the fan maybe bad itself. You can also try - turn on the AC, this will activate the 2nd (booster) fan, and should help prevent serious overheating but wont fix the underlying problem.
Good luck
Jul 13, 2011 | 1999 Mazda 626
Daewoo lanos 98 model. Only one radiator fan works, which is overheating the car.
only one is suppose to work the other kicks on when you turn ac on turn ac on does it come on now let me no and i can help you more from there check water level do you have the correct amount of water in resevior of car when car heats up half way fan kicks few minutes later fan should kick off with ac off of course sticking thermostat can cause car to over heat
Dec 08, 2010 | 1999 Daewoo Lanos
My 2003 vw bug dies and won"t start when i run the ac on very hot days. sometimes when i"m driving all the instrument panel lights all come on ant then it loses power to aprox 5 mph. I checked the...
ENGINE GETTING TOO HOT AC PUTS MORE LOAD ON ENGINE AND OUT SIDE TEMPERATURE HOT.YOUR CAR TELLING YOU I AM HOT AND NEED A BREAK.MAKE SURE COOLANT LEVEL NOT LOW AND THE COOLING FANS RUNNING WHEN AC GOING IF NOT CHECK FAN FUSE IF FUSE GOOD.YOUR THERMO SWITCH NOT WORKING OR THE COOLANT TEMPERATURE SENSOR AND FAN CONTROL MODULE COULD BE THE PROBLEM IF THE FANS DONT TURN ON.
Jul 15, 2010 | 2001 Volkswagen Beetle
1999 Alero: where is the a/c control tempature :problem is wh...
WELL TURN ON AC MAX COLD HIGH TO SEE IF COOLANT FANS TURN ON.IF NOT YOUR REFRIGERANT SO LOW THAT THE AC REFRIGERANT PRESSURE SENSOR WONT CLOSE CIRCUIT TO TURN ON COOLING FANS.MEANING YOU NEED HAVE AC CHECKED AND CHARGED.ALSO CHECK COMPRESSOR FOR POWER IF NOT YOU HAVE BLOWED FUSE OR BAD RELAY.IF FUSE AND RELAY GOOD YOUR AC COMPRESSOR CLUTCH COIL OPEN OR THE AC CONTROL SWITCH IS BAD.IF COMPRESSOR IS RUNNING WHEN YOU TURN ON AC YOUR AIR TEMPERATURE ACTUATOR NOT WORKING.
May 17, 2010 | 1999 Oldsmobile Alero
99 Chevy Siverado AC works then quits
low 134a coolant, you may have a pin hole leak, or just need topped up on 134a. wallmart or most auto parts stores sell 134a kits. also check your rad coolant.
Aug 13, 2009 | 1999 Chevrolet Silverado 1500
1999 Chrysler Town and country A/C Problem
your evaporator is most likely leaking unless you have rear ac then check the lines going back if it is just front ac the evaporator 90%of the time is you culprit .this is book time 7.8 hours off labor the dash has to come out.but napa or other car parts places sell stop leak with 134a.also get the tool to put it in.
May 23, 2009 | 1999 Chrysler Town & Country
Ac not working in 2003 beetle
Hi, My AC just stopped working last year and it had to to with a sensor thing that is located on top of the battery. It was a rather constly repair, about 350 bucks. Hope this helps.
Apr 14, 2009 | 2003 Volkswagen Beetle TDI
How to access ac blower and fan switch, 1999 Volkswagen Beetle?
if its work in only low speed u have to replace the blower motor resstor which located close to the blower
let me know have a good one
Mar 31, 2009 | 1999 Volkswagen Beetle
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
