Question about Envision G19LWK Monitor
OUt of Range
The image is grainy and shifted slightly to the right. A message in the center of the screen reads "Out of Range"
    Problem Solver:
  • 6 Answers
"Out Of Range" means your video adapter is set to a resolution/refresh rate setting that is outside the range of supported signals.
Go into your Video Adapter's settings, look at resolution then the refresh rate (Hertz), and compare to those supported by the monitor.
When I had a similar problem, I noticed that somehow, the refresh rate was set at 59HZ which is unsupported. After changing to 60HZ (which is supported) the problem went away.
Posted on May 06, 2010
Vertical black bar on my LG 47" LCD shifting the image to the right
Two possibilities are there. The first one is, with loose LVDS cable, that connects the T'Con board to display panel. The second is the fault with its main digital processor board.
May 21, 2013 | LG 47LC7DF 47 in. LCD HDTV
06 nissan murano camera. The screen shows the
NO, the back-up camera is a 6 volt camera on the Murano.
Feb 21, 2010 | 2006 Nissan Murano
Blue convergence is shifted right slightly
CHECK FOR THE SUFECE MOUNT CAPACITORS AT THE SMALL CONVERGENCE CIRCUIT BOARD
Jul 13, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Center of picture is soft (out of focus)
paulc846,
There might just be a smudge or fingerprint on the lens, that's enough to cause that to happen to the center of an image. Get some lens cloth on a q-tip and try to gently wipe it clean. If the image is really grainy and the camera has recently been dropped the sensor is damaged. Let's hope for the smudge.
randy320sgi
Jan 03, 2009 | Canon PowerShot SD600 Digital Camera
Blue Ghost
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
Dec 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Entire image shifted
Press the Select/Auto button. The monitor will then automatically adjust to match the incoming signal and will save that setting in the internal memory of the monitor.
Nov 06, 2008 | Hyundai L90D+ 19" LCD Monitor
Image Shifted to the Right...
did you go into the service mode, only a good technician should go into there
Jun 22, 2008 | Toshiba TZ50V51 50" Rear Projection...
The image turned very colorfull and grainy
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor
Aug 01, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Envision G19LWK Monitor Logo
293 people viewed this question
Top Envision Computers & Internet Experts
Steve
Dimitar Todorov
Paul Bade
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
