Question about HP Officejet 5610 All-In-One InkJet Printer
Its printing alot of weird words and things all crazy
Its not making no sence and just keeps printing that over and over again
Text being scanned does not produce a clear print to our cannon ip18oo printer
alot of the time if you scan something it will streach the image because of the scanner resolution. check you setting on the printer. you might need to change the settings to stop it from doing that to make he image more clear. if that doesn't work than also some printers are just like that when you scan something. it will also make one page turn into two pages. that may just be the way the printer is.
Aug 13, 2008 | HP Office Equipment & Supplies
P Touch 1880 indicates MAX font size, but prints smaller sized label. If I print one word at a time, it prints in MAX size. If I print two or more words, it prints smaller font. Weird, new problem.
Sounds like you may have a maximum length set that keeps you from printing over a certain length of label and it is adjusting your font size to fit that length. You may need a manual to figure out how to reset the length.
Jan 14, 2011 | Brother P-Touch 1180 Label Printer
I have a HP Photosmart Premium C309a and it prints word documents fine but it only prints the first column of spreadsheets. Nothing else from the spreadsheet prints. Just the first column. Very weird. ...
I doubt any problems in the printer.
From your'e spreadsheet, Select printing range and print preview the sheet. If all appears on screen then print it.
good luck
Nov 08, 2010 | HP Office Equipment & Supplies
PRINTING ENVELOPES FROM MASTER LIST IN WORD-HOW TO GET THEM TO FEED AUTOMATICALLY?
They wont, its a way to make sure that you have envelopes in the MP tray..
Alot of my customers ask the same thing, there is no way to change that.
Oct 14, 2009 | Kyocera Copystar CS-1820 Black and White...
HP 3380 making weird sounds.
Check for blinking lights on the control panel to determine if there is an error (consult your documentation for troubleshooting)
If you cannot determine there is an actual error, reinstall the printer's drivers.
1) Unplug any connection to your computer from this device (usb wire, scsi, cat-5 cable)
2) uninstalling the drivers from the hardware menu
3) reboot your PC
4) confirm the printer is no longer installed on your PC by going to the printers section of your control panel.
5) Follow the installation proceedure ducumented for your printer.
6) restart your PC if requested, if not go to step 7
7) test that you can print to your printer.
If this does not fix your problem, contact HP support. They may have more information for you. I'm seeing alot of these HP LJ3380's today. are they all yours?
May 08, 2009 | HP LaserJet 3380 All-In-One Printer
Printing problem
Perform several Head Cleaning cycles and do a Nozzle Check. If the nozzles are still clogged turn the printer off overnight to allow the ink to soften and then try cleaning again.
Oct 22, 2008 | Epson Stylus RX500 All-In-One InkJet...
Bad printer
try to save the documents to microsoft words application then print it
Mar 17, 2008 | HP DeskJet 5550 InkJet Printer
Only printing partial page
hp psc 1315 printer dead due to lighting send me circuit drawnig
Dec 12, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
