Question about HP Photosmart 3310 Printer
HP3310 problem with shadowing in background while scanning and printing
HELP. I thinnk there si something that needs to be cleaned but I cannot figure out how to do it!!
  • 474 Answers
Re: HP3310 problem with shadowing in background while...
Buy the maintinance kit for it and follow the instructions. The kit usually has a roller that has a cleaner that cleans out the printer.
you could also try pulling ouit the ink cartdridges (DONT WEAR WHITE CLOTHES WHILE DOING THIS) getting a paper towel dabbed with warm water and cleaning the contacts on the ink cartdridge and the connectors in the ink carrier in the printer, theres often buildup after alot of use.
Use compressd air to blow out any dust but after you clean the ink out, no sense in bloing ink particles all over the place.
Posted on Feb 16, 2008
0 characters
3 Points
There is a faint background shadow covering the
remove toner/drum unit from the printer. remove toner from drum unit and shake toner cart. side-side to loosen toner inside. On top front of the drum unit there is a purple/blue button that will slide right-left. Do this a few times to clean the wire. If there's a lot of loose toner, take a vacuum and clean carefully. Put everything back inside. With front door still open, hold GO/Control button down until all lights have lit, then let go, close front cover.
If you still have the shadow over the page, it's most likely the toner cart and you need to buy a new one (or recond.-refill) at someplace like Office Depot or Staples.
Jan 20, 2010 | Brother HL-2040 Laser Printer
ADF Reader, Black lines
Open ADF (automatic document feeder) cover and clean scan glass underneath. White out or post-it notes are notorious for leaving behind residue on glass when scanned. Any dot, spot or dirt will show up as a black line due to shadow effect.
May 15, 2009 | Canon Printers & Copiers
Won't print
The printe will not scan or print. When I fax documents it is recieved witha balck shadow in teh background. I get error 2200 when I try to print or scan.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Shadow print from 2200d laser printer
This shadow, or backgrounding, is generally caused by excess debris remaining on the drum. This is mostly caused by the wiper blade not dislodging all the waste toner. You will need to replace the cartridge (C4096A).
Mar 22, 2009 | HP LaserJet 2200D Printer
Sooty background won't go away
You most likely need to get a maintenece kit on it what that includes is the fuser. It could be tht the fuser itself is damaged or has burnt toner on it causing it to apear dirty
Feb 12, 2009 | HP LaserJet 2605DTN Color Printer
Mfc 5840cn acts like its printing but does not
is this when printing from pc or just making copies? if its about copying, gray background may be caused by the scanning mechanism.
Nov 18, 2008 | Brother MFC-5440CN All-In-One InkJet...
I have been scanning slides from my HP3310 all in one and have found that dark images will not scan. Is there something I can do about this. Chris
the light in the scanner is not so powerful that it cannot read the dark images properly.
you can do one thing using adobe photoshop reduse the dark ness of the images and then try to scan it will.
hope this helps....
Oct 06, 2008 | HP Printers & Copiers
HP 2420dn printing gray and shadows
maybe the scan unit need to clean first you most sure that the toner cartridge is original and new then start clean th scan unit reflector d9b88f3.jpg
Mar 12, 2008 | HP LaserJet 2420dn Printer
HP Photosmart 3310 Printer Logo
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
