Question about JVC AV-27230 27" TV
JVC and the right converter box and antenna
I have a AV-32D203 JVC that the three different converter boxes and antenna I have tried does not work, it have to be the tv; do I need a special antenna for JVC model?
    Genius:
  • JVC Master
  • 1,550 Answers
If the tv got audio video inputs put the converter box on it,because any converter box got to work with all tv´s
Posted on Jun 30, 2009
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
Connecting an Antena to a JVC 20220 how do i set up the tv to find channels?
Unless you are lucky enough to be close to one of the remaining low-power analog stations, you will need additional hardware to watch over-the-air programming with the AV-20220. You will need a digital to analog converter box. Connect the antenna to the converter box and then connect either the antenna output or the composite output to the appropriate input on the TV. If you use the RF input, set the TV to channel 3 or 4 and set the converter box to the same one.
Then to set the TV up to scan for any NTSC (analog) stations, you need to access the menu. There is a menu button on the remote. (I'm not sure about the AV-20220. Some of the later models (AV-27350) have a menu button on the TV as well.) Press Menu several times until you see Initial Setup (Setup). Use the up and down arrows (Volume) to navigate to Auto-Tuner Setup. Then use left and right arrows to choose Air. Use the up/down arrows to navigate to Start. Then press either the left or right button to start the scan for channels. Wait for the scan to end.
I hope this helps.
Mar 07, 2014 | Radio Communications
DO I NEED A DIGITAL CONVERTER TO OPERATE A 4 YEAR OLD JVC MODEL AV-32D305 WITH AN ANTENNA?
If you have cable running to your house, cable still uses RF and older TVs work fine. The problem comes when you try to grab stations from the air. The signal is still UHF, but the information riding on that UHF signal is digital, and will need a converter box to turn it back to analog so your older TV will understand it. . Cable: None needed. . Antenna: Need a box.
Nov 25, 2009 | JVC AV-32D305 32" TV
Does the JVC AV27230 require a digital to analog converter?
if you are going to continue using the rooftop antenna, then you will nee to purchase a digital converter box. Those television sets are only analog. You do have an option to get Directv or Dish network and you will not need a converter box at all. Directv and Dish network are 100% Digital and the receivers work as converter boxes for that product only.
Jun 16, 2009 | JVC AV-27230 27" TV
I have a jvc tv model av27530. Disconnected cable box b/c going
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Jan 09, 2009 | JVC AV-27530 27" TV
Will the JVC TV model AV-27820 mfg 1997 become obsolete i n February?
It will still work fine if you have cable or satellite. If you are using an antenna to receive broadcast signal you will need to get a digital converter box from an electronics store like Best Buy. You can get discount coupons from the federal government good for 40 dollars towards the converter. Google "Digital Covnverter Coupon Program" and it should give you a link to the site to apply for up to 2 coupons.
Best wishes
Jan 04, 2009 | JVC AV-27820 27" TV
TV converter Box
yes it will require a converter box if you don't recieve cable or satellite
Dec 31, 2008 | JVC AV-27D305 27" TV
Jvc model digital ready
I'm sorry, but this model is not digital. You will need a converter box if you use an antenna.
Nov 15, 2008 | Sanyo DS24424 24" TV
DTV Question
Based on the features described by JVC and the technical details listed on Amazon.com the answer is no, no digital ATSC tuner, just NTSC analog.
So yes, she'll need a converter box for the ATSC over the air signals.
Jan 16, 2008 | JVC AV-27D201 27" TV
JVC AV-27230 27" TV Logo
416 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
