Question about Whirlpool EL05CCX 4.3 Cu. Ft. Compact Refrigerator Including Full Size Storage Door and Freezer Comp...
Half moon cubes too large. Intermittent harvest.
Cubes were too small.
I adjusted fill timer to make larger.
now cubes too large.
harvest cycle ejects a stick of 8 conjoined half moon cubes in one lump! For the two days the harvest cycle is stalled- no cube ejection.
I'm old [80] with failing short term memory.
I forgot which way
[clockwise-counter clockwise]
to turn which screw
[beside the wheel-in corner of base-plate], and
how many degrees of rotation
[1-360] to make with the screwdriver
in order to reduce water fill time and
enjoy normal sized half moon cubes.
Please advise.
Flatbedfred
  • 4,070 Answers
Counter clockwise should decrease it. Just turn it 1/4 turn each time and check it after it makes another batch of ice. Then reread this post and do it again till it's the way you want it.
Posted on Jun 30, 2009
Cubes too thick What is the normal timer setting
There is a screw on ice maker that adjusts the amount of water that enters the tray. Adjust that for required thickness of cubes
Jul 18, 2015 | Kitchen Appliances - Others
Nothing is cool no ice or anything but the fan in the freezer and the fan bottom rear are working continuously
If your icemaker is producing small cubes, hollow cubes, huge cubes, or a solid slab of ice, one of the first things you want to check is the fill level. And it's not as difficult as you might think. (Hey, the hard part's wrenching that bottle out of Pookie's little fingers!) Unplug the refrig, pull the icemaker - usually one screw underneath, either 2 more or hooks above the cube mold - and unplug it. Take it to your sink and melt out any cubes with hot water. Then plug it and the refrig. back in, leaving it unattached from the freezer wall.
Manually start a 'harvest cycle' (see below) and hold Pookie's bottle under the fill tube. You'll have to wait a few minutes, because the water enters near the end of one complete rotation of the cube ejector, which constitutes a 'harvest cycle'. Regardless your type of icemaker, you're looking for 130-150 cc's, with most working best around 145cc's, but anywhere in this range should work OK.
(When replacing your icemaker with a new one, always check and adjust the water fill level this way too. You'll save yourself a lot of trouble.)
Jan 18, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The Icemaker is not making ice there is water from the dispenser cube of ice get stuck in the mechanisim that makes the ice and causes the arm that turns off the ice making to be activitated
if ice is to small it get's stuck during the harvest cycle . / remove the front cover of ice mker and there is a adjust for larger cubes this will correct problem . now if water valve is getting bad it may not be able to deliver enough water . in this case replace valve . mm
Aug 11, 2010 | Frigidaire Refrigerators
Scotsman cme 506ae-1a harvest to soon. Where is the adjustment timer the harvest is also too long?
The water float rod in front of the unit serves as the fill stop as well as the harvest initiate. Difficult to remove to clean really well but not impossible. Harvest time is handled by the controller. First two or three harvests are long as the controller times out the harvests based on the blinking light of the bin full indication. After that is should get shorter.
Jul 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
Jul 14, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My scotman model sce170a1a.goes into harvest to
That has to be a faulty control wouldn't you think?
cover.
cycle.
Feb 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice maker makes very little Ice and the cubes are small.
The amount of ice is not dependent upon water flow, well as long as you do have flow, when enough water is in the maker it will shut off the supply.....ice quantity is dependent upon the length of the freezing cycle, the shorter the cycle the more harvests per hour. Adjust the timer so that you get complete freezing, but just barely
Jan 16, 2009 | Whirlpool GS6SHEXNL Side by Side...
Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Nov 06, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Refrigerators Logo
100 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
