How o pace spool pin
I'm not sure what you're asking. If you're asking how you can replace the spool pin that is on the machine, you don't need to. Just put your spool in the back of the machine, away from the sewing area on the right, and put it in a coffee cup or Mason jar, and feed the thread from there. Many owners of embroidery machines--which are just sewing machines with an embroidery unit attached--routinely do that--it tends to feed more evenly that way.
SOURCE: how do i replace the spool pin on my singer sewing
Two ways.. either put the new spool pin in the other extra hole to the left of the trap door on top OR take out the two bigger screws on the top cover that hold it in, also take off the knobs on the front sliders (patters selection) and remove the top over. Push the old pin out from the inside with nail or something simila and replace.. simple. Do you have an extra spool pin you can share?
SOURCE: how to replace spool pin on model 5160 singer sewing machine
Drill and tap out the broken bit. Put new one in.
SOURCE: cannot replace spool and casing back into 760 singer sewing machine
Here's is a downloadable manual for the 740 and the 760.
http://www.singerco.com/uploads/download/1268_740-760.pdf
SOURCE: how do you detach the horizontal spool pin from Singer sewing #ll20
There is really no reason to do that unless it is broken.
