Question about GoVideo DV2140 DVD Player/VCR
Dvd drawer will not open
Hi. All of a sudden the dvd drawer will not open. Troubleshooting this problem is not in the manual. Tx.
    Genius:
  • GoVideo Master
  • 1,550 Answers
You need to disasemble and change the motor charge belt
Posted on Jun 30, 2009
Pos troubleshooting
Replace the printer port
Feb 20, 2014 | Retail Supplies
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
Hi, I need a pioneer dvl-909 service manual that tells how to replace the loading belt. Thanks, Bill
Try to see if the drawers are blocked by something either inside or outside of the case.
Mar 17, 2012 | Pioneer DVL-909 DVD Player
DVD drawer will not open. Any ideas? System is a couple of years old but just out of box. DVD drawer will not open
Hi:
Check the bottom of the DVD for a lock mechnasim, most manufactures lock the mechnasim in place for transport to vendors. Also check the user manual for more info on this procedure.
May 21, 2011 | Insignia IS-HTIB101 Theater System
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
The DVD door will not open when the button is pressed
Please check the bellow instructions:-
Turn off your DVD player. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Please get back to us if you have any further query or else accept the solution.
Nov 01, 2010 | Panasonic NVVHD1BS DVD Player / VCR Combo
The DVD drawer will not open on the model TT 320
Hi
Thanks for using FixYa. Please locate the DVD player’s manual eject button which is a small hole located underneath the DVD drawer. Now insert a stiff wire like a paperclip or safety pin into the hole and push gently to open the drawer. Now pull the drawer gently to open it. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling then you need to remove the label. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player and you need to have it serviced.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | TruTech TT320
DVD drawer will not open on Zenith ZHX-313....help???
hi friend,
Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs. If this is the case you should have it serviced or perhaps it is time for a new one.
I hope this helps.
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Zenith ZHX-313 System
Dell Modem CD Drawer Won't Open
Yes. There should be a very small hole on the front of the CD/DVD drawer. Insert a straightened paper clip into this hole until you feel it push a button, and this should manually release the drawer.
Nov 05, 2008 | Computers & Internet
I own a RCA DVD recorder, having problems with the drawer/door opening
This is in the wrong area...you are writing this under the Hoover Floormate H3000 vacuum troubleshooting area
Aug 23, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
GoVideo DV2140 DVD Player/VCR Logo
112 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
