Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
I have a gordon digital electronic safe # P45891, lost combination .how to open it?
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Posted on Jul 15, 2009
  • 1 more comment
  • Tammy Martin
    Tammy Martin Nov 24, 2013
    There is no screw in the front where the number pad is
  • Raul Guevara
    Raul Guevara Mar 23, 2014
    remove the SKU. I didnt know the screw was there so i pried off the cap. Dont do the same mistake i did. Pill the sticker and youll see the phillps screw head. And for the authur of the above. Thank you so much for your help. Sinc, RG
  • leonard gordon
    leonard gordon Mar 09, 2017
    un screw now what I do
I have the same safe. Try 159a
Posted on Jul 13, 2009
  • Jay Finke
    Jay Finke Jan 30, 2011
    IF YOU HAVE THE DOOR KEY , TURN KEY LIGHTLY AND DROP THE SAFE ON THE GROUND,ABOUT 6 INCHES, (JUST LIKE THE ONE IN THE PICTURE)THIS WILL JAR THE ELECTRIC SOLENOID .YOU MUST DO BOTH AT ONCE. IT MAY A FEW TIMES..IF THAT FAILS TAKE YOUR HARBOR FREIGHT GRINDER WITH A CUT OFF BLADE AND SCORE THE DOOR IN THE CENTER FROM TOP TO BOTTOM, (DON'T CUT THREW OR IT WILL BURN UP ALL OF YOUR STUFF !) USE A LARGE SCREWDRIVER TO THEN PRY THE CENTER OF THE SAFE DOOR UP.. ITS A JUNKY SAFE, BUT THAT'S A GOOD THING 4 U . GOOD LUCK AND IF'N I WAS OF HELP COMMENT VOTE (TELL ME SO I CAN BRAG ON HOW DERN GOOD I'AM).. CUZ IF I CAN;T FIX IT I'LL BREAK IT TRY'N.. Jay longwood Fl
I have a Gordon Digital Electonic Safe SKU#45891. Have forgotten combination. How do I open it? Solve this. Topgun44
Posted on Apr 01, 2010
What does the key look like? batteries down and safe got shut.
Can I get a key for the safe? How much???
Posted on Mar 15, 2011
  • robert mays
    robert mays Feb 24, 2017
    same as above ,batterys down,lost key,how do i get a new key..
    New Friend:
I have a gordon digital electronic safe # Password:h0885, lost combination .how to open it?
Posted on Mar 29, 2015
    New Friend:
Have a Harbor Freight safe? On the small Harbor Freight safe model 45891 the batteries will go dead without warning. Many people have these as a bedside gun safe. If you lost the key (or left it inside with the book) you can't get back into the safe, the barriers are on the inside and there is no way to charge or power them from the outside. Here is how I opened my safe. Remove one screw and keypad to expose the back-up key lock. Face the front of the safe and drill a 1/8 inch hole 3/4 of an inch to the left and 5/8 below the key lock's center. This hole will be close to the left edge of the keypad recess and covered by the keypad plate when you reinstall it. Stick in a stiff small wire like a paper clip and once through the door plate you will hit the solenoid pin, total distance from front to pin is 1.250 inches until you hit the pin. Once you hit the pin you need to slide your wire up the pin just a little bit until you fell it go over the top, then push the wire in 1/4 inch more and push down on the pin then turn the door knob, the door should open. There is also a large washer 1/4 inch below the pin top, you can bend the wire at a 30 degree angle 1/4 inch from the end and maybe a few more small bends to angle the wire down after it gets through the door plate. You can also push down on this washer to open door. The washed is a larger target and depending on how well you drilled your hole this may be a better spot to try to push on. Also, holding light pressure on the door knob with a rubber band glued to the knob (or light hand pressure) while slamming down the safe's bottom "hard" on concrete will open it. This causes inertia to jar down the very lightly sprigged solenoid pin long enough for the door knob lock plate to slide over the top of the solenoid pin. Rather your contents will survive the impact is another matter. David, BransonKC0LL Tucson, AZ
Posted on Aug 29, 2014
  • Steve Yribe
    Steve Yribe May 25, 2015
    worked perfect, thank you so much
How do I open my digital safe SKU#P45891 when the number code no longer works?
This sounds like a job for a professional safe cracker.
Jan 25, 2017 | Home Security
How to change the code on my gordon digital electronic safe
Most inexpensive electronic safes have a reset button inside. Push that and then enter the new combination and finally press the button you normally use to unlock. Confirm the new combination works before closing the door again.
Jul 04, 2014 | Safe International Digital Electronic Safe...
Gordon electronic safe and can't open it
Wow , I have the same safe thats been locked for more than a year.
I locked the keys in the safe and forgot the code.
I took the thing out side and droped it on its corner and whala.
go figure it worked ,thank you to who ever was the first 1 to try that
cody in west palm beach,fl
Feb 13, 2010 | Safe International Digital Electronic Safe...
I have a digital electronic safe home protection. I have lost my keys and the battery is dead I have had thi safe for nearly 2 years
1) look again for the key
2) call a lock smith
3) drill the lock
these safes arent expensive , cheaper to drill the lock and replace that a lock smith , but get a quote
Oct 09, 2009 | Safe International Digital Electronic Safe...
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
Resetting code
Go to harborfreight.com; click on safes picture in the right column; then click on the safe that you have (#45891); then click on the instruction manual download icon at the bottom. This should solve all your problems.
Feb 16, 2009 | Safe International Digital Electronic Safe...
We have a Gordon Digital Electronic Safe sku#P45891 . The original pin code that we set it too is no longer working. We cannot get into the safe.
Put the safe on your lap and bounce it on your knees and keep tying to turn the knob I had it opened in less then 10 seconds! And the batteries were dead this really does work.
Jan 08, 2009 | Safe International Digital Electronic Safe...
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
10,671 people viewed this question
Top Safe International Locks & Locksmithing Experts
Marvin
Marvin
john h
Jay Finke
Jay Finke
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
