Manual portable Looking for free owner's manual for Royal Custom II
SOURCE: I need free manual for Royal ER 145. Recently
Here Goes Program 2 position - enter 102420 att/total key - program 1 position enter o in the departments as non tas enter yy mm dd (09 04 23) hit charge key
enter time hhmm (1500) military time hit xtime depress amout tend key turn off and on and maybe will work for your child...Good luck......have fun
SOURCE: resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
SOURCE: my keys are locled on my royal kmm 1941 typewriter
Margin Release should be near the top of the keyboard on the left or ride side of the keyboard. You may have a sticky margin lock bail or a spring loose or broken on the bail mechanism if the margin release doesn't work. Sometimes the linkage for the bail needs to be adjusted. If you are mechanically inclined, you can possibly follow it through, but if not, seek out a service tech.
SOURCE: How to replace ribbon on Royal Apollo 10 elec typewriter???
The cover either pulls up straight or there is a release lever in the front part of the cover that pushes.
SOURCE: Need to re-set margins on Royal electric typewriter
Use the green code key with the rm and lm keys.
