Question about Car Audio & Video
I changed batteries in both remote control units and now neither one works. I've checked to make sure the batteries are installed properly (+ on +) and they are. When I press the TX button, the LED indicator does not light.
  • rgable794 Jun 30, 2009
    The batteries were installed correctly so I bent the contacts on both ends in slightly. The LED indicator now lights and both remote control units operate properly. Thanks for a simple fix to what could have turned into an expensive repair.
    Sergeant:
    Novelist:
  • 198 Answers
This could be a battery issue. Try using regular alkaline batteries.
Although it might seem that secondary batteries like NiMH and NiCd, which can be recharged, are always to be preferred, that is not true. Many electronics device applications call for such low use of battery "charge" that secondary batteries self-discharge long before they discharge by use. In that case a primary battery (e.g., alkaline), which usually self-discharges very slowly, is to be preferred. On the other hand, for power-hungry toys that are used extensively and frequently it pays to use secondary batteries because they discharge by use rather than by self-discharge. Keep in mind your application when selecting a battery.
In addition, note that NiMH and NiCd batteries provide only about 1.2 volts, whereas alkaline batteries provide about 1.5 volts, the difference being due to their different chemistries. Some devices will work properly with a primary battery (e.g. alkaline) but not a NiMH.
Posted on Jul 01, 2009
  • 13,433 Answers
Double check that all the batteries are set the right way, look on the bottom of the remote and see how its marked.
If the batteries don't touch properly the light wont light.
Posted on Jun 30, 2009
Just bought Topfield TRF2100, screen on and says"installation", but remote won't work.
Be sure there are fresh batteries in the remote. Be sure they are installed correctly and that there is nothing covering the remote's battery contacts. Look to see if there is a film covering the remote's infrared lens or the receiving unit's eye. Check your manual to see if you need to program the remote to the unit. if it's a multi-unit remote, be sure that you have set it to control the specific unit you're working with.
Jul 17, 2015 | Televison & Video
First the receiver red light was on constantly so i changed the batteries and now it's not lit at all?
Make sure the new batteries are installed properly.
If they are installed properly, then replace them AGAIN with new batteries. The new ones you put in may be faulty.
Do not assume that "new: batteries are good. Some Dipsh&t at the grocery store where you bought them may have dropped them on the floor six months ago, and broke the 'internals' (the "innerds").
Verify they work by installing them in another device, like the TV remote or such.
Clean the metal thingies where the batteries go in. Clean the ends of the batteries.
BANG THE REMOTE ON THE TABLE, and cuss at it.
Really. Gadgets (remote control units) sometimes respond to a bit 'o banging around, I am not kidding here. Cussing is optional.
Take the batteries out, push ALL the buttons a few times, and then replace the batteries again.
Good luck, have fun.
(Oh: and make sure the batteries in the RECIEVER are fresh, too!)
Yeah, there are likely batteries in the "other end" of the gadget, also.
Bang the remote on the table, and cuss at it a bit. It is much more rewarding when done in such fashion.
Trust me: this has been frustrating enough that you posted the question online. Get your "money's worth" out of the solution.
Good luck, and have fun!
Mar 06, 2015 | Ambient Technologies RCSTE Hand Held...
I've changed the batteries in BOTH remotes for out Vermont Castings Fireplace, and made sure the "remote control" setting is set on the fireplace itself Why won't they work with new...
Make sure the batteries are in correct and then I would be concerned with the send receive unit in the fireplace. Is it an IR remote (needs to be pointed directly at the receiving IR) . If that is the case then the IR receiver may be blocked or covered. If this is an RF remote then you don't need direct line of vision and I would look at the receive unit.
Dec 25, 2014 | Heating & Cooling
Remote control for vmb070 does not work
There should be a clear indication on your remote where the battery compartment is. Usually there is a slideoff cover that has to be removed. Some remotes have covers that are difficult to remove. Once you have the compartment open, you can remove the batteries. Check for signs of corrosion inside the compartment and clean it before installing new batteries. Be sure to observe proper polarity when installing new batteries
Mar 17, 2013 | Televison & Video
Remote doesn't control on/off,volume or channels
Remote won't workThe most common reasons the remote won't work is that the batteries are dead or it hasn't been programmed properly. It's often easy to fix. Here are the steps to take to troubleshoot the problem.
Make sure you have a clear path between the remote and the infrared eye on your equipment. Clear any dust or debris that may be covering the eye.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Press the SAT mode button at the top to unlock it. Your remote should work properly.
Check the batteries. When you press a mode button, does it light up? If not, you may be out of juice. Check to make sure they are in the right way, with the metal ends making good connections with the metal in the remote. If they're in correctly and you still don't get power, try replacing them. They may be dead.Learn about batteries
Check to make sure the remote is programmed properly, which basically means you reprogram it to work with your receiver, TV and any other components. Start with the receiver and work your way through programming each component that isn't working. We tell you how to program remotes in our guide to remotes.Learn about remotes
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.Be prepared to tell us:What components you have.All of the steps you've been through to try and solve the problem yourself.Can't change channels on receiverThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Make sure you are in SAT mode. The receiver will only change channels when the remote is in the correct mode.Look for a timer. If you have a timer set, the receiver won't let you change channels. This ensures you don't miss recording a program with an external device. If a timer is set and you want to watch another channel, simply turn off the receiver and turn it back on.Learn about timers
Make sure the problem is with the remote and not the receiver. Try the buttons on the front of the receiver. Try to change channels. If your model doesn't have channel buttons, try to turn the machine off. If you can't change channels or power off, the problem is with the receiver. Try unplugging it for two minutes and plugging it in again.
If you can change the channels or power off, the problem is with the remote. Press any mode button on the remote. It should light up. If not, you probably have low batteries. They should be replaced.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Click on any of the mode buttons at the top to unlock it. Your remote should work properly.
Try re-programming the remote to talk to your receiver.Find the manual for your remote control
Check to see if your Shaw Direct Receiver is using the same remote control address as your remote control.If you are using the DSR 319, HDDSR 505, or HDPVR 530 receiver press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate to 6 - System Setup and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 4 - System Setup. Then 3 - Installation Settings. Followed by 2 - Remote control Address.If you are using a legacy receiver such as the DSR 315, DSR 405, or any other receiver with front panel buttons, press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate OPTIONS and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 6 - Change System Settings. Then 3 - Change Installation Settings. Followed by 2 - Set Remote Control Address.Follow the on-screen instruction to reset the remote control address on your receiver and remote control.Check the back of your remote, if you own the IRC/URC 550 or RT-U50 remote controls you will need to enter the remote control address differently from what is displayed on screen. To program these remotes, hold the ENTER and MUTE button on your remote at the same time until the mode buttons at the top start to illuminate then enter the last three digits of the number displayed in "Current Address" column on the screen, then press the MUTE button to lock in the code. For example: If the remote address on the screen displays 0002, you would hold ENTER + MUTE until the mode button illuminated and then enter 0 0 2, followed by ENTER on your remote control.If you own the IRC 551 or URC 551 remote control you can follow the instruction depicted on the screen, but you must substitute the follows numbers in place those specified: 00869 for 0000, 01870 for 0001, 01871 for 0002, 01872 for 0003, 01873 for 0004, 01874 for 0005, 01875 for 0006, 01876 for 0008. For example: If the remote address on the screen displays 0003, you would hold the SAT button until it flashes, press 01872, then ENTER, to lock in the new code.Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Can't control TV volumeThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Press the volume button on the remote. The TV mode should light up. If not, you probably have low batteries. They should be replaced.
If the SAT button lights up, you are in the wrong mode. Press TV and try again.
Try re-programming the remote to talk to your TV.Find the manual for your remote control
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Thank you for using Fixya, Hope this will help your problem.Don't forget to rate me.thanks,Reymond
Oct 18, 2011 | JVC AV-27850 27" TV
My remote won't work and I used to be able to change the channel on the TV but even that dosn't work. I checked the cords. Changed the batteries;
Hello
First check its battery contacts for any rust or dirt accumulated on it. If so, contacts of battery will not touch properly, and the unit will fail to work. The second reason for malfunction is due to the infrared sensor inside your tV. If it is faulty, the set won't respond to infrared signal generated by the remote control. If so, eventhough remote control works properly, the set won't work with it.
Remote sensor comes just behind the infrared window at the bottom front panel of your TV. It is a replacable part and not so costly too. It is a three terninal component will look brownish black in colour. It will looke like this.
gopakumarg43_77.jpgThe procedure to check the remote control for its perfect working is described at a tip I've given and published by Fixya on Google. Type "gopakumarg43" on google search box, and get into my profiles. There you can see 'Tips and How To's" line, click on it. You can read it there. OK.
Sep 23, 2011 | Philips Magnavox 20MT133S 20" TV
I've got one single 12000 btu ac unit and one double 24000 btu unit and three wall units controled by 3 remote controls.Recently one of the remotes stoped to work.I've changed the batteries(were...
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | LG LS-K1830CL Cool Mini Split Air...
Remote does not work unless I am in the garage. Outside the door it will not work.
hello emar... check to be sure that the little wire antenna is hanging down from the back of the garage door opener motor. Then check it. If it still won't work from outside, install new batteries.
If that doesn't do it, remove the new batteries and use the eraser end of a common pencil to clean the battery contacts inside the remote. then reinstall the new batteries and try it again.
May 04, 2011 | liftmaster 83lm Billion Code 3-button...
My remote for a Bose Wave Radio does not work any more. It just stopped one day. I replaced the battery and have made sure that the battery is properly installed (positive side up). I have unplugged and...
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Aug 19, 2017 | Bose Additional Wave radio II remote...
My remote no longer works powere on/off or volume on my LG plasma flat screen
Install new batteries and make sure to install with correct polarity, i.e, + to + and - to -.Ensure you are pointing the remote control directly at the TV. Check to see if there is any object between the product and the remote control causing obstruction. Ensure that the remote operating mode is set to TV. If you cannot set the remote properly, please give me the model number of your unit.
Oct 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
