Question about Batesias LM2010 20 in. LCD Television
Remote Control Hi, My remote contol no longer works to my Batesias 20.1" LCD series TV I am having trouble finding a remote to replace the old one with. Where can I find a new one that my TV will be able to read? The model # is BCT201 series
Re: Remote Control
I also own the Batesias LM2010, which I purchased 4 years ago for the PIP function (still a rare feature on a 20" LCD TV). While I do not have any problems with my Batesias remote, I prefer to use a universal remote, which I have programmed to operate all my audio-video equipment in the room. The remote I am using is an older Sony RM-VL700S, and it works perfectly well with the Batesias LCD TV. I assume that most decent programmable universal remotes will do the trick, although I am partial to Sony. (You can find a number of Sony remotes in the RM-VLxxx series for sale on eBay and at electronic etailers such as
Posted on Mar 04, 2008
Re: Remote Control - Batesias LM2010 20 in. LCD Television Flat Panel Televisions
Can i ask where did you buy ur tv?
Posted on Jan 11, 2008
0 characters
3 Points
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from
Coby tv remote doesn t work Questions & Answers - Fixya > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
Remote control for batesias television
Hi there I got a Kameleon all in one URC-8206 remote contro works fantastic and totally upgradable via web recommend this product.
Thanks J
Feb 21, 2008 | Batesias LM2010 20 in. LCD Television
Remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Jul 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Need the remote contol code for AOC L26W861 Lcd TV
Just kept repeating the U-Vesre procedure over and over and Wham! Persistance was the key.
Jun 12, 2009 | Flat Panel Televisions
Remote stopped working!
To turn off the 100 button you need the original remote.
Order a replacement from one of the sellers below:
Used Original Zenith Z20LCD1 Remote Control
Zenith Z20LCD1 Replacement Remote
Mar 09, 2009 | Zenith Z20LCD1 20 in. EDTV-Ready LCD...
Remote controle ccode HV207t
I think all universal remotes ****. Never found one to work with my TV. has the remote in stock for the HV207. It should work for your TV. They have pics of it, I bet it looks the same as your old one.
Feb 04, 2009 | Proview HV-207 20 in. HD-Ready LCD...
Universal Remote Control for Batesias LCD TV
As far as I know, Sony does not have a code which works with the Batesias products; as I recall, I tried the code search function to no avail. I simply used the learning function to program each button's signal. This is the preferable method anyway, since it allows you to customize each button on your universal remote. For instance, I often include such TV functions as PIP on/off in the controls for my VCR component. I hope this helps.
Mar 27, 2008 | Batesias LM2010 20 in. LCD Television
Akai 32" LCD TV/DVD Combo- universal remote
just replace the infrared diode of your remote control in you dont know how to do that..ask the tecnician to change in infrered diode in your remote control
Feb 04, 2008 | Akai LCT3201AD 32 in. LCD Television
Batesias LM2010 20 in. LCD Television Logo
183 people viewed this question
Top Batesias Flat Panel Televisions Experts
Jaime Hernandez
Are you a Batesias Flat Panel Television Expert? Answer questions, earn points and help others
