Question about Frigidaire FRT21S6A Top Freezer Refrigerator
Freezer cool but not freezing
Ice cream turns to liquid
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models they don't have the timer but an electronic device which replaces the timer.
Posted on Jun 30, 2009
How long to freeze bucket
Homemade Ice Cream Freezing Methods - RecipeTips.com
www.recipetips.com/...tips/.../homemade-ice-cream-freezing-methods.as...
Rating: 5 - ‎2 votes
Jump to Ice Cream Maker Using Ice - This type of freezing process is known as a "stir ... Place the covered ice cream can in the bucket, making sure it is ...
equipment - How long do I need to freeze the freezer bowl ...
cooking.stackexchange.com/.../how-long-do-i-need-to-freeze-the-freezer...
Dec 30, 2010 - Is a couple of hours in the freezer enough, or do I need to wait until tomorrow morning? ... This really depends on your freezer and your icecream bowl. Usually ... How to clean ice from ice cream maker bowl without thawing?
[PDF]Frozen Yogurt-Ice Cream & Sorbet Maker - Cuisinart
Jan 14, 2016 | Ice Cream Makers
Ice cream does not seem to freeze it is always very soft. Everything else freezes O.K.
hi icecream generaly depends on the mixture & consistency need more clarity....
All fresh ice cream is somewhat soft, but should not be liquid. It will never be hard like it is in store. Let it churn until it is the consistency of soft ice cream, and then let it harden a bit in the freezer to get to the consistency you want. It's possible you actually let it churn too long and it started melting again.
Another method I used is to just put the ingrediants in the bowl, put in the freezer, and then take it out of the freezer and churn it myself, moving a butter knife around the edges to get all the frozen parts out, then a fork to mash it up. The ice cream takes less time to freeze and is generally harder
Aug 08, 2011 | Refrigerators
The freezer has been melting ice-cream
The first thing to do is, give it a FULL DEFROST, the old fashioned way. set it for defrost or unplug it and melt all of the ice out of the air tunnels below and behind the freezer. In the refrigerator section, you will find a hole that you can stick your finger into, normally in the wall next to the freezer. This has the defrost timer in it. Give it a full turn CLOCKWISE to make sure the contacts aren't stuck. When you are sure all the ice is melted and the water has been dried up, power it back up. It will run properly if nothing actually went bad. The next step, if it doesn't work right, is to replace the thermostat.
May 27, 2010 | Samsung RS2630SH Side by Side Refrigerator
Cuisinart Ice Cream Freezer Bowls Not Freezing Anymore
I would take the freezer bowls out of the freezer, run them both under the sink to thaw both bowls out, dry both bowls thoroughly, and then set them both on the counter so that the liquid settles toward the bottom of the freezer bowls. After 1 hour, place the bowls FLAT back into the freezer - don't forget to wrap them in a plastic grocery bag or some other sort of plastic bag. Try to make ice cream again after 24 hours or more of freezing. Let me know if this works, so I can pass the good news along to others.
Aug 03, 2009 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Not setting / freezing - bowl in freezer 24 hours *
The ice cream mix has to be xconstantly stir in a nrine solution, That's why they have motorized ice cream makers that rotate the can surrounded by ice and salt.(brine) while a paddle inside stirs it. Good luck and enjoy.
Jun 01, 2009 | Disney Ice Cream Maker
Ice cream not firm
The freezer bowl is sensitive. Go ahead and thaw it out until you can hear the liquid swishing around inside - usually letting warm water run through it is sufficient for thawing. Then refreeze the bowl, making sure the bowl is sitting flat/level in the freezer. When making ice cream with this unit, letting the freezer bowl sit out for even 20 minutes can unfreeze it enough so that you only get sludge. Do not remove the freezer bowl until you are immediately ready to pour the ingedients into the bowl. You can even pre-chill your ingredients by letting the ingredients sit in the freezer for about 15 minutes - although I have found that this usually has the opposite effect of what you have just experienced --> the ingredients usually freeze up so fast that the mixing paddle is no longer able to turn.
-Tha Mp3 Doctor
Mar 16, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
My freezer bowl not freezing anymore I let in the freezer more the 24 hours and it's still liquid
Thaw the bowl and re-place it in the freezer - make sure it is sitting perfectly level. Don't remove the freezer bowl until you are immediately ready to pour in the ingredients - letting it sit out for even 5 minutes will be too long, as it thaws quickly.
Jul 17, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Freezer bowl not frozen!
Preparing the Freezer Bowl:
The freezer bowl must be completely frozen before you begin your recipe. The length of time needed to reach the frozen state depends on how cold your freezer is – for best results, place the bowl to the rear of your freezer where it is coldest. In general, freezing time is between 6 hours and 22 hours. To determine whether the bowl is completely frozen, shake it. If you do not hear liquid moving, the cooling liquid is frozen. For the most convenience, leave your freezer bowl in the freezer at all times so you can take it out any time for immediate use.
Features and Benefits:
  • Freezer Bowl – The double insulated freezer bowl contains a cooling liquid between the bowl walls to create fast and even freezing. In general, the required freezing time of the bowl is 6 to 22 hours before use. Additional freezer bowls are available separately for making double batches or different flavors without interruption. For additional information on preparing the freezer bowl for use, please see below.
  • Base and Motor Unit – The base contains a heavy-duty motor that is strong enough to handle everything from thick, rich ice creams to smooth frozen yogurts to slushy frozen drinks . The base unit features a generously sized on/off switch, rubber feet to prevent slipping and keep the unit stationary while in use as well as cord storage to keep counters neat and safe when the unit is not is use.
  • Lid with Ingredient Spout – The easy-lock, transparent lid secures to the base with a simple turn, allowing you to watch the freezing process as it progresses. An ingredient spout at the top of the lid is generously sized for pouring in ingredients and ideal for adding nuts, fresh fruit, candy pieces and more without interruption the freezing cycle.
  • Mixing Arm – The mixing arm mixes and aerates your frozen desserts and drinks, incorporating and blending all ingredients thoroughly.
  • Instruction/Recipe Book - The included instruction and recipe booklet helps you get started with over 30 recipes and variations for ice creams, sherbets, sorbets, frozen yogurts and frozen drinks.
  • Feb 29, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
    Ice cream has ice crystals in it
    Ice crystals are more prevalent in homemade ice cream because it takes longer to freeze the mix. When you can flash-freeze the ice cream to very low temperatures very quickly, there is less time for the molecules to melt and refreeze, which causes crystal formation.
    Here are some of the useful tips:
    1.) When the ice cream is done, transfer to the coldest part of the freezer as quickly as possible
    2.) Pre-freeze the ice cream bowl before using, and pre-freeze the storage container before putting the ice cream in it and into the freezer
    3.) Make sure the mix is very cold before using the machine. Maybe put the mix in the freezer for 15 minutes before starting the machine, so that it will finish faster
    Hopefully this information helps a lot.
    Jul 09, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
    Frigidaire FRT21S6A Top Freezer Refrigerator Logo
    199 people viewed this question
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
