Radio Communications Logo
A
Anonymous Posted on Aug 07, 2014
How to squelch adjusment on ic-v68 - ICOM Informatique Radio Communications
BJ Russell
Level 2:
Sergeant:
Champion:
  • Expert 214 Answers
  • Posted on Sep 10, 2014
BJ Russell
Expert
Level 2:
Sergeant:
Champion:
Answers
214
Questions
Helped
55873
Points
508
1 Related Answer
Anonymous
  • 55 Answers
  • Posted on Nov 05, 2008
SOURCE: Squelch adjustment on IC-F21
Is it a UHF radio or GMRS/FRS?
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Can you change the squelch setting on an ICOM F61V
The squelch setting can only be changed with dealer programming software. A Manual for this radio is available from http://www.icom.co.jp/world/support/download/manual/pdf/IC-F51V_F61V_3.pdf
How to get rid of busy
Remove Battery and insert again, reprogram it, adjust squelch level.
Squelch control of ic-2000 does not function
In what way. Does it never receive? If that's the case, chances are the CTCSS (Tone Squelch) is on. If it never mutes the speaker, the squelch circuit may be defective.
2answers
1helpful
2answers
Squelch is open all the time
Often the potentometer (squelch control) becomes worn or dirty, this can be sometimes cured by spraying a WD40 or similar oil and then rapidly moving the control down and up. Do not use oil that is conductive.
No sound- audio IC amp ok, squelch circuit or squematic needed- thank you
Well my friend I have same problem with some radio. Maybe you should try just to connect detector to audio amplifier and than make an squelch circuit in AF?
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
Larry Ng
Larry Ng
Jim
Level 1 Expert
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
