Question about Brother MFC-5840CN All-In-One InkJet Printer
Printing I work in an office with several networked computers. Some of which are linked to the Brother all in one. For some reason, since yesterday, it is not connected - although no connection has been severed.It kept beeping and saying there was a problem with the paper feed. This was checked and is fine. The machine is set to fax but I am not sure if someone has meddled with the various menu facilities.Could you confirm what and how to reset to connect with the printers again using the menu buttons and whatever else is necessary on the keyboards at by the copying lid?
  • 832 Answers
You should run the brother admin tool which can be downloaded at the homepage of brother of your country. After installing you can see and do the settings of the machine.
In case you simply want to check the setting get the network manual (download at brother homepage). It will explain how you can print out all setting being made to the machine and how to change them.
Posted on Nov 08, 2007
Brother DCP-195c error prinr unable 73
I suggest You Go to Official Brother Printer trouble Page For You Brother Printer Problem On Below Brother Printer forum URL Link:
I Hope You resolve Your Brother Printer Issue,
In case You Need Online Assistance Then follow Us For ON:
Brother Printer Support
Feb 01, 2014 | Brother DCP 165C Compact Color Inkjet...
I had the Brother mfc 490 CW connected to a lan network and it was working OK. Just two days ago I unplugged the printer and moved it to another spot in the same room connected to the same lan. When I...
"No Station ID" means that your printer is in the mode "Transferring faxes to another fax
Brother has a Solutions Center.
I add a link to this center, hope it will help you resolve this problem asap.
United States Brother Solutions Center
May 30, 2017 | Brother MFC 490cw Color Inkjet...
I can't print to my printer from MS Office 2007 . I have done all the trouble shooting and my computer detects the printer, prints a test page, etc. When I send a Word document, it shows it being sent to...
Hi, please make sure the brother printer is selected before pressing print.
Now goto Wordpad , can you print from there ? if yes then there might be a problem with the office install but most likely the wrong printer selected , if there was a issue with the driver or printer the test print would not work, make sure that you don't have dupilcate printers.
Nov 30, 2009 | Brother HL-2170W Laser Printer
Brother MFC-6490CW is not printing black
If it's under warranty you're in luck, you need a new printhead,LK3197001, around $80.00. I just replaced one yesterday in the shop for the same problem. I would call Brother customer service and see if they'll help cover the cost.
Sep 04, 2009 | Brother MFC 6490CW InkJet Printer
Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
Jun 30, 2009 | Brother MFC 490cw Color Inkjet...
Can't scan with mfc-7840 w, has worked fine for months, on laptop with xp, was working in another office for last 10days, came back to home office and it can't recognize device at all I can ping IP no...
I had a similar problem. I was able to print and scan for months and then all of a sudden could not scan anymore (from printer or through software interface). I then found out that the IP address for the scanner was not set properly. To fix this, goto control panel and scanner and cameras. Right click on the MFC7840W and select PROPERTIES. On the network setting tab, make sure that the IP address is the same as that on the MFC7840W.
Mar 31, 2009 | Brother MFC 7840W Printer
Brother MFC 790CW does not print on Network
Please define several others that are close. If Brother doesn't list a Linux why would you expect it work?
Nov 06, 2017 | Brother MultiFunction Center MFC-440CN...
Sharing printer
there are several things involved for the for the other computer to stop printing.Is ts printer a print server ?? if yes the make sure that the computer which is not printing is on the network with the same domain.note the name of the print server..
  1. Click on start menu and click on Printers and Faxes.
  2. A new window will appear.On the left side on the window click on add a printer..
  3. A wizard will appear then you click on next..
  4. Click on Network printer, or a printer attached to another computer
  5. click on next
  6. Click on browse for a printer and then Next
  7. The computer will browse for all printers shared on the network so you will have to choose the printer you want to connect to followed by next.
  8. After adding the printer you set it a default.
Enjoy printing...
Please get back to me soon if there is any results..
Jan 09, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC-5840CN All-In-One InkJet Printer Logo
54 people viewed this question
James Cagle
James Cagle
Jim Keysor
