Question about Canon PowerShot A620 Digital Camera
Camera will not power up correctly
After pressing the on button when in camera mode (the lens is currently in the extended position), the camera buzzes briefly, the LCD screen does not activate, the lens does not retract and the camera shuts down. When in playback mode the camera buzzes briefly, the Canon chirping bird appears and chirps then the screen and the camera shuts down. I have changed the battery and memory card with no change in the problem. The camera has not been dropped and is in very good condition. It was purchased new in 6/06. I bought a Canon Power Shot a620 in July of 2006. It will not power up at all. I have tried new batteries, cleaning the battery contacts (which are spotless anyway). I have never dropped or abused this camera in anyway and have used it very little. I am hoping that the factory will stand behind there product and am sending it in today.
  • 2 more comments
  • johnsacco Nov 27, 2007
    I dropped my camera and it now only powers on when it is pointing down. It works completely fine but only if it is not pointing straight ahead. As soon as I tilt it up to point it straight ahead it powers off. If it is upside down pointing up or sideways, it WORKS. It stops working when it is pointed straight ahead or when i tap on it. Obviously something is loose. Is there a common part that I would look at?
  • Palomitz Jan 20, 2008
    I have the same problem with my Canon A620. The camera does not turn ON at all. I have tried many batteries, new and rechargeable, and still does not work. It is dead. Can anyone help?
  • Anonymous Jul 08, 2008
    I purchased a Canon A630 on April,2007. Installed new battery and cleaned battery contacts, camera failed to power up. Pressed and held power button, no respond at all. No dropping was happen to this camera.
    Any one has any idea?
  • haraldstoll Feb 26, 2009
    ey gys, same issue here:
    Device was working fine, took a bunch of pictures, slided to play to show my friends and then it turned off with the lens still showing.
    now the machine will not turn on at all, new batteries, nothing.
  • 22 Answers
Again the same old compact camera zoom lens problems - sand in lens, stuck AF motor, chewed up plastic gears...you only have to look at them wrong and they will die... (A very cynical camera repairer that has tried to repair these damn things soo often!!) Even cameras with internal lenses like the old Nikon 950/990/4500 still have troubles with stuck motors and broken lens parts. I despair - these things are just made to last the guarantee out (if that long) and die horribly afterwards!!
Posted on Jun 16, 2008
Camera has charged batteries. at first when i turned on power...nothing happened...then...later...i pressed power again and it came to life. the lens popped out and i took a bunch of pics and reviewed...
@ alan o'brien, Samsung D53 digimax draws a lot of current from the battery thus, you need to replace your batteries with a HIGHER current ratings, sufficient enough to run the motor. This miniature motor inside the D53 camera drives the reduction gears functions, to extend and retract the mechanical lens. During this processes it is drawing a lot of current from the battery. In order to conserve and prolong battery power avoid zooming in and out, utilize the function speed 50-400 and manually adjust aperture to minimize the unnecessary use of flash. In other words, go manual mode. Here's the battery specs. 2800ma NiMH rechargeable battery. Refer and follow manufacturers recharging instructions for best result. Do not leave batteries inside the camera even when not in use because the circuit inside is still on the standby mode and not necessarily off. Hope i have satisfy your curiosity. If you can, kindly share with me some of your best photo taken from your D53 digimax. Thank you.
Sep 22, 2013 | Samsung Digimax D53 Digital Camera
Tip
Fix lens that won't extend fully
If your A360 only extends the lens partway when you turn the camera on in picture mode, there is an easy solution that requires no technical knowledge whatsoever. Mine exhibits this behavior most of the time, and I've experimented it with it and found that these two things help:
1. Hold the power button down the entire time the lens is extending. For whatever reason, this seems to help.
2. If your lens extends only partway (if this is the case the screen and all pictures you take should be blurry), simply hit the macro mode button (the little flower to the left of the zoom) twice. This works because when you go into macro mode, the camera automatically brings the lens to its lowest zoom, which is meant to bring the lens back from a high zoom, but also works in reverse. You may have to repeat this procedure a couple times each time you start the camera (you'll know it's fixed when you no longer hear the motor whine when you press the button).
One last tip: if you've had this problem before and you start up your camera and it seems fine, use trick number 2 anyways, just to double check that the lens is indeed in the correct position. I've made the mistake of assuming, based on the fact that the picture on the screen looked sharp, that the lens was fully extended. When you look at your pictures, you may find that all of them (even those taken with a tripod!) may be blurry.
on Aug 03, 2008 | Fuji FinePix A360 Digital Camera
Len extended will not retract and the green led on the back tilt whe I keep press the power button
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 09, 2010 | Insignia NSDSC10A Digital Camera
Cant turn camera off. lens is out for zoom. When I press button it just clicks. Eventually says lens error. restart camera.
Jul 08, 2010 | Canon PowerShot A1100 IS Digital Camera
I've canon power shot SX120 IS, when press on/off Button the camera shut ot but lens didn't come in. the lcd says "lens error, restart the camera"
Jun 21, 2010 | Canon PowerShot SX100 IS Digital Camera
Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
Press the shutter button halfway
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 | Cameras
Viewfinder and LED display both black.
Try pressing the power ON and when the lens has retracted, remove the batteries. Wait a few minutes. Press the power ON again. Now replace the batteries and try the camera again.
Aug 20, 2009 | Nikon COOLPIX P60 Digital Camera
Lens Error - Restart Camera : Lens remains in extended position.
I had the same problem with the same camera. Ended up twisting the lens by hand back and forth while powering the camera on and off till the lens pins finally realined and let it close properly. Took alot of patience and care but has worked since. Usual cause of this problem is powering camera while the lens is blocked from extending, ie in a case, laying on its face etc.
May 28, 2009 | Canon PowerShot SD870 IS Digital Camera
Lens won't open and retract.
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 03, 2007 | Kodak EasyShare CX7530 Digital Camera
Canon PowerShot A620 Digital Camera Logo
172 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
