Question about Adobe Photoshop Elements 2.0 for PC
Electrical lights dim while driving , battery light comes on ,squealing
    Problem Solver:
  • 19 Answers
Are you talking about your car or Photoshop?
If its your car I can almost bet the belt that runs the alternator is loose and It sqeals during aceleration. take it in a have someone take a look at it to make sure it is not anything more serious.
Posted on Nov 09, 2007
Why does battery light come on dimly, then goes out after a bit?
Diagnosing Common Automotive Charging System Problems
Sep 18, 2013 - Dim lights. ... Problem: Engine starts OK, but the battery does not stay charged. ... Solution #2: If the battery won't hold its charge and your engine stalls out,then it's time to ... Problem: The charge indicator light comes on while driving. .... It's OK if the wiring of the toggle switch goes to B+ or the alternator B+ ...
Alternator Problems -- Diagnosing Electrical Problems ... > Autos > Do It Yourself Auto Repair
Jun 24, 2013 - Diagnosing alternator problems can be a bit tricky in certain ... After that, the alternator takes over. ... Your lights might begin to dim, you'll lose power, and then, the car ... be able to turn on the headlights, or they'll come on but very dimly. ... So before you go out and order a new battery or a new alternator, ...
What causes the battery light to be on? ' Mustang Forums at StangNet > ... > SN95 4.6L Mustang Tech
Jan 01, 2016 | 2007 Chevrolet Trailblazer
2006 KIA spectra squeals when started- worse when the lights and/or heater is on and when it is wet or cold. The lights will also dim sometimes at a stop when the lights, heat and other stuff is on and...
Check the condition and tension of the drive belt on the alternator as what you have described means that the extra load on the alternator is making the belt slip (squeal)
Oct 08, 2013 | 2006 Kia Spectra
What could be wrong if lights get dim inside car when turning on outside lights
Weak battery, dirty battery cables or a defective alternator.
May 10, 2013 | 1999 Ford Taurus
I had a routine tire rotation and car alignment on yesterday. As I drove my car later in the evening, the vsc/ecm dash light came on, followed by the brake and battery light, radio and dash lamp lights...
Sounds like you lost the charge from the alternator.
When the alternator quits charging your battery light comes on and your car will run on battery power only...and only for a short time.
As the battery gets its stored energy used up...everything that is electrical will get slow or dim.
I'd check your alternator for proper operation and its drive belt...
Hope this helps...
Aug 14, 2011 | 2003 Lexus LS 430
All,dash lights came on-gas,all,then power dies down,lights conitually go dim,car quits running,before this i heard a squealing noise,what is going on w/car
Could be a bad alternator diode and it wasn't keeping the battery fully charged, which could be indicated by dimming lights, loss of power, or completely quitting when voltage becomes too low to properly fire plugs.
The squealing could have been a locked up alternator (probably caused by a bad bearing) and the drive belt is slipping on the drive pulley, making the squeal.
Hope this is of some help.
Dec 26, 2010 | 1998 Kia Sephia
Possible electric short. Lights dim on occasion(all lights, including headlights), clock/radio display went out for a couple of weeks then came back on and now the rear passenger brake light is out. Also...
squeal sounds like lose alternator belt and that would make sense if belt sliping lights will dim rear brake light probley a bulb radios dispaly may have short or just going bad
Feb 17, 2010 | 2004 Pontiac Sunfire
Issue with dash lights dimming while driving,
If the battery and alternator tested fine. I would have the charging system rechecked when engine is hot and at high rpm's. This way the checks are being done as if you were driving and driving for a long time. Alternators can work fine when cold but weaken when hot or stop working. This problem is not rare but only is seen occassionly. Unless it was checked at an electrical shop the average shop doesn't run these tests for they don't see the problem often enough to automaticly run them at all times. Good luck and let me know how you make out.
Sep 21, 2009 | 1998 Volvo V70
At normal operating temperature, dashboard lights dim, clock dims
Alternator bearings dry change the alternator again You should get a new one under warranty if its only 5 months old.
Jun 07, 2009 | 2000 Hyundai Elantra
The lights dim down when i use anything electrical
check the battey cable if one of them loos if not try to but anther battery cause sometime the battery get crack in one of the termenal if its still happend try to replace the ALT relay with another one
Mar 15, 2009 | 2005 Mazda 6
Adobe Photoshop Elements 2.0 for PC Logo
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
