Question about Microsoft Xbox 360 Console
Can i use an Xbox 360 bought in USA in India - given the voltage conversion required? would there be any seperate adaptor available for 220 volt usage in India
    New Friend:
Hi i have a 220 volt xbox and it doesn't work, i bought a volt converter and it still dead !!! I don't know why. Any ideas ?
Posted on May 27, 2013
    Genius:
  • 1,019 Answers
yes you can, you,ll have to purchase a stepdown Transformer, which is 220-240 Volts AC.
This will reduce the voltage from 220-110V. They are available but will need to be a good quality one ( usually the size Of the power Brick ) I,d suggest the worlds largest on-line marketplace :-) Or Radio-shack Maplins.
Mike @ Compurepair.
Posted on Jun 30, 2009
    Problem Solver:
  • 10 Answers
Yes you need a usa to india convter
    Problem Solver:
  • 10 Answers
You can purchase a volt adapter (rather common in travel stores/airports) but over time the device's power-supply will wear out because of the frequency difference.
North America runs at 60hz
India runs at 50hz
India 220watts how I cAn use brother cs6000i sewing machine in India
The only way I know is a 110/220 volt transformer.
They are available in any electronics supply house.
As I remember the motors in these machines are only two lead, and they put the motor in for the country it will be sold in.
Dual voltage motors have three or four leads (wires).
Jul 28, 2015 | Brother CS6000i Computerized Sewing...
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 17, 2012 | Microsoft Xbox 360 with Kinect
Xbox adaptor burns by over voltage
You should buy a new power adapter of 220V. Your Xbox should be safe. I faced similar situation when I pulgged my xbox in India and this was resolved by buying a new power adapter.
Dec 06, 2011 | Microsoft Wireless Network Adapter Xbox...
I bought a GE microwave oven model wes1450dm1bb at the USA, but now I am in a different conutry that uses 220 volts as standard. I just read the user manual and in any place says the voltage of the...
No, You'll burn up the appliance. When I was in Germany there were commercially available transformers to step the current down. The transformers plug into the 220 sockets and provide several 110 sockets to plug your appliance into. We purchased several transformers and ran our 110 tvs, kitchen appliances and other 110 appliances. The 220 sockets in Germany were different than 110 and 110 plugs sould not fit.
Feb 23, 2011 | Ovens
Hi...i have an New Revlon Hair dryer which was bought from US to INDIA n it is not working due to the difference in Voltage to that of US i guess....So could you please suggest me is can i get i repaired...
The voltage of the dryer you are having is 120 volt as compaired to the voltage in India 220~230 volt AC at 50 hz
You can use a simple thyristor voltage controller which will work out cheaper.
If not a step down transformer is needed to bring the voltage from 230~120 V.
As a transformer is expensive then it is possible to get the conversion done with a voltage reducer- solid state.
Sep 11, 2010 | Dryers
I bought a BOSE system in chicago. now in India not working
Electricity in India is 240 Volts, alternating at 50 cycles per second. You will require a voltage converter if you are carrying a device that does not accept 240 Volts at 50 Hertz. Check the voltage selector atthe back and set it to teh correct voltage - if not present buy an adaptor. Your component will have to be examined by an expert. Click here for repair locations in India.
Jun 15, 2009 | Bose (321GS) System
Altec Lansing VS4121, New Speakers, No Sound
If the speakers are brand new it makes me wonder how you know they worked fine in the States? I am also wondering how they were transported due to them probably being intolerant to extremes of temperature/humidity and probably vibration.
I am also wondering if you are using the correct supply voltage and type of supply.
If you are using the power adaptor supplied for use in the USA, it would probably be incompatible with your supply even though you are using a transformer.
If you are certain the speakers are in good order I suggest you obtain a power adaptor designed for your 220 volt 50Hz supply. I have browsed a little and cannot find a note of the power requirements for the integrated amplifier but this is presumably marked on the adaptor, the speaker or in the manual and so the power adaptor could be checked on and off load with a suitable voltmeter. I would be surprised to learn the supply is adequate
Apr 01, 2017 | Altec Lansing VS4121 Speaker
110 volt usa xbox 360 to work in a 220volt country
The first possibility is that it was simply a faulty transformer, however the more lilkey problem is the transformer was not of a sufficient power to run the Xbox 360, you need to make sure that you buy a transformer that can supply at least 300w of power as this is what the xbox 360 requires, some cheaper models may have difficulty with this.
Further information about step down convertors can be read here
Thanks,
Geoff
Apr 17, 2008 | Microsoft Xbox 360 Console
XBOX 360 Power Adapter
What happened when you switched on the console? I think the 360 is supposed to run from 240v (at least that's what it says on the power brick) 220v may not be enough to power the console. You may have damaged the console but I'm unsure as I've never run into this situation before. You could try another power brick making sure you use the correct voltage. I'm sorry if this isn't much help but please rate if at all useful, thanks!
www.360solutions.eamped.com
Nov 25, 2007 | Microsoft Xbox 360 Console
Adaptor not working?
You need a transformer-type adapter that takes an input of 220-240V and steps it down to 120V output. If you bought the unit in the USA, you may have a problem if it is NTSC-only and doesn't have a NTSC-PAL switch to select the correct video format for India.
Dec 21, 2017 | Durabrand DUR7 Portable DVD Player
Microsoft Xbox 360 Console Logo
1,276 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
