Question about Toshiba MK8026GAX (hdd2191) 80 GB Hard Drive
Windows xp does not recognize my Toshiba external hard drive
ModelHDDR250E03X I installed the hard drive and transfered data and it was working fine for about a week. When i went to safely remove hardware i kept getting a message that the Generic Voice was in use and to try again later. I disabled the Generic Voice and now my computer will not recognize the external hard drive
Valiis
  • 72 Answers
SOURCE: Safely Remove Hardware
Sometimes this can happen with Generic Drivers.
Make sure you installed any drivers that came with the device, and if they didn't come with any try going to the Manufactures website and downloading the drivers.
Posted on Jan 02, 2008
showsizzler
  • 66 Answers
SOURCE: WD Passport Portable Hard Drive 120 GB Problem saftly removing hardware. Receive the message 'h device ' Generic volume' canot be stopped right now. Try stoping the device again later.
well i cannot actually figure out your problem well all windowsxp and windows vista allows you to safely remove your usb device well wats the error like diid you check microsoft for lates updates and patches !!try it oderwise tell me the exact error or problem!!thanx
Posted on Feb 01, 2008
msuhelk
  • 106 Answers
SOURCE: seagate external hard drive - would not open
TRY THAT EXTERNAL DRIVE IN OTHER PC AND CHECK IF IT IS RECOGNISED THERE, BECAUSE IF IT IS NOT RECOGNISED THERE ALSO THEN LIKELY YOUR CASING IDE CONNECTOR *** CONVERTER HOUSING HAS PACKED UP.
Posted on Apr 05, 2008
DrunkenMonk
  • 6 Answers
SOURCE: Maxtor OneTouch 500gb external; delayed write failure, etc., on disconnect
1) Always make sure your system is clean of viruses and use scandisk to check the file system's integrity - no point making changes to a system based on corrupt files, as things will likely stay corrupt. Try scanning the registry too with your favourite registry scanner.
2) Use a program like Sysinternals (Winternals now under Microsoft) ProcessExplorer. If a process really IS using the USB drive, then you can do a search for exactly what is being used by searching for "<DRIVE LETTER>:" and interpreting the results. Malware could be using it or just a program you were running hasn't correctly 'signed-off'. You can force-close the offending item if nothing else works. Then the drive should allow itself to be safely removed.
3) Check your USB chipset drivers. Install any updates available, or if none are, then uninstall & reboot, then re-test.
4) Power is the baseline for everything electronic, people forget this too often. If you can, check the PSU (an external one I assume with this model of drive) with a multimeter.
5) Try on another PC (preferably with the same OS) at length.
6) Try with a different USB cable.
7) Try with the Firewire cable as a workaround (the hardware/chipset used is different, so likely to encounter different hardware/software issues, but interesting to check if any similarities).
GOOD LUCK - I hate USB, it's so fiddly with all the different driver/chipset/hardware implementations that it can be a nightmare to troubleshoot.
Posted on Aug 09, 2009
paper bag
  • 72 Answers
SOURCE: My computer isn't recognizing my new Toshiba Roco
If it is new and has not worked at all, you should try using it on another computer that, if possible, has a different operating system. My first option would be to create a partition using a 3rd party partition creator.
Posted on Dec 26, 2009
Can i transfer information to a mac
If the external hard drive has been formatted on a PC in NTFS file format then the MAC cannot read data off this hard drive.
The FIX..
Connect the USB external hard drive to a Windows computer and copy your data off this hard drive to the computer.
Then format the external hard drive in FAT32 file format. (the MAC can read and write to data to and from a Windows PC)
Now copy the your data from the computer back onto the external hard drive.
Now you can connect the external hard drive to the MAC and download your data to the MAC.
Feb 22, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
I have a toshiba satellite laptop A135 series and it won't recognize my toshiba external hard drive. However, the drive works fine with my HP
This can be an issue with the USB port, or the drivers.
Is the hard drive a Power HDD ? that means it has 2 usb chords one for power and one for data transfer? coz those might not work with laptops, also has it ever worked with the laptop ?
Thanks
If this was helpful, then kindly rate me.
Nov 10, 2010 | Toshiba Satellite A45-S121 Notebook
I recently bought a Toshiba Satalite laptop to replace the one I dropped which was also a Toshiba Satalite. I had taken out the old hard drive and installed it in the new one but now it wont do anything...
Yes it does matter. XP was configured for the old Toshiba and this will only work if both Toshiba laptops are exactly the same model.
To get your new Toshiba operating, put the new hard drive with the Vista operating system back in the Toshiba laptop.
To transfer your data from the old hard drive, purchase a USB adapter hard drive case and place the old hard drive inside this case. This will then be an external USB hard drive.
Plug this USB hard drive into the new Toshiba's USB port and it will detect it as an external storage/hard drive. You can then open the various folders and files and copy the data files to your new Toshiba.
To free up disk space on this USB hard drive, delete the Windows folder, Program Files folder and other folders that are no longer needed.
Use this hard drive as a backup hard drive etc.
Sep 11, 2010 | Toshiba Computers & Internet
Transfered contents to a terabyte drive weeks ago. Not recognized
thats a file system related problem, try to download this file systems repair tool, let see if work. download data recovery wizard tool from this link. http://www.easeus.com/disk-copy/download.htm
Apr 13, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Oct 31, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Hard drive is not recognize by the computer
Both XP and Vista have this feature that requires that new installs of hardware be certified by Microsoft within anywhere from 30 to 60 days from installation.
Run an install (not a clean install which will wipe your data, mind you, but an install accomplished by installation disks, where you will be asked which kind of install you wish to accomplish, and you will be asked to register your software using your product key)
If you need additional information, I will be more than happy to assist you.
Apr 07, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
Acomdata external harddrive is not recognize on vista
I had a similar issue with windows 2008 and windows 7. the drive lost all its info and had to be reinitialized under both of those O.S.'s..
You can try that as long as it doesn't have any data you need.. Once you do that the drive will work and you can start using it. The file system under vista and above is slightly different than xp.
Sep 12, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Won't recognize on windows XP(SP3)
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 10, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Toshiba MK8026GAX (hdd2191) 80 GB Hard Drive Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
