Wont Start, Flywheel turns but makes a winding sound ran fine then just stopped without warning
Check the blade on the mower. Make sure it is tight and that the shear pin has not been broken. There is a shear pin on the crankshaft that keeps the blade from turning along with the nut that holds the blade on. designed to break off if you hit something with the blade. That is so it doesn't bend the crankshaft. Also make sure that the starter works and that the gear that turns the flywheel has not broken off a tooth.
SOURCE: Toro ride on mower won't start
Try replacing your spark plug. If that fails then go to the engine, cheak your carb, lines, and gas. cheak for gum in the engine/carb. If gummed then get carb cleaner and spray twice, wait 1 hour then try again. If my solution fails then you might need expert help. Good Luck!
SOURCE: craftsman riding mower repair starter will spin but not engage
You need to buy a Starter Drive Kit. If you starter has a flat piece on top held on by a retaining ring, it's part # 696541. If you have the older type starter with roll pin holding the drive on, you need part # 696540. You probably have the first one. To install the retaining ring, use a 3/8 socket to tap it into the groove. Dwain
SOURCE: cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
SOURCE: My riding mower will start by pull cord but not from ignition
Jump the solinoid with a screw driver, it the engine starts, replace the solenoid.
SOURCE: mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
