Question about Frigidaire PLD4375RFC Dishwasher
Frigdaire Quiet II - Dishes in upper portion are not coming clean
My dishes are not all clean when done washing. Also it doesn,t sound like the not a lot of pressure when washing like it did when it was newer.
Posted on Jul 06, 2009
Whirlpool dishwasher doesn't make the regular sound
The problem could be a clogged water line or intake valve. Check the lines and make certain they are open and flowing.
Feb 26, 2014 | Dryers
Maytag jetclean dependable quiet plus doesn't clean dishes
It sounds like you have a faulty float switch. It's cutting off the water inlet before the tub is full.
May 26, 2012 | Maytag Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Wont clean dishes
The little holes in the spary arms can block with general gunge etc. We use toothpicks, skewers to clear them. That sometimes helps.
Nov 16, 2011 | Dishwashers
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Top rack dishes not getting clean
Hey- Two things could be wrong.- clog, or bad motor. Sump screen needs to be cleaned of debris. Removal of sump cover to access screen requires torx bits and some patience. Replacement of pump requires pulling out dishwasher to access bottom. Motors fail when seal between motor and pump fails. Will still operate, but become weaker over time. Parts available- motor about 100$ at appliance parts pros.appliancepartspros. Hopes this helps- Thanks- ED
Feb 26, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a whirlpool quiet partner II dishwasher. There is a gritty residue on the dishes in the top rack and on some of the silverware. Any suggestions on how to fix this?
MAKE SURE THE UPPER WASHER ARM IS NOT CLOGGED, SOMETIMES FROM DETERGENT BUILD UP IF YOU'RE USING POWDER DETERGENT. CHECK ALSO FROM THE BOTTOM IS THERE'S ANY DEBRIS THAT MAY PREVENT THE WATER GETTING TO THE UPPER WASHER ARM
Jan 16, 2010 | Whirlpool Dishwashers
The dishes don't come out clean after complete cycle or even after I re did the wash.
Has it always been okay in the past? Do you have the manual, and if so, are you loading it properly. I am not familiar with this particular machine, however there are a few things you can check. Make certain all the spray arms are spinning freely. If there is a "tower" that comes up from the bottom, be certain nothing is blocking the center portion of the bottom rack. Run a load as normal, but stop it after a few minutes. Is there water in the tub and are the dishes wet? If not, determine if the water source is on, and the "fill" solenoid is working. If there is water, and all dishes appear to be getting wet, be certain you are getting a lot of "water action" during the wash. If you listen closely, you should hear a sloshing sound as the machine runs. If not, your not getting enough water circulating. The pump may be clogged, or perhaps there is not enough water coming in. Is your water pressure high enough to fill it completely? I hope I have given you enough things to check in order to lead you to the problem. Let me know.
Oct 31, 2009 | Maytag MDB7100AWB Dishwasher
Frigidaire PLD4375RFC Dishwasher Logo
174 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
