Question about Asko W6441 Front Load Washer
Not only is my asko washing machine leaking, the code "F3" flashes continuously, and my clothes are locked inside. What does "F3" mean? and how do I get the door to unlock?
  • 725 Answers
F3 is a blocked drain...open coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Hope it helps if NOT let me know more about your problem... and I will help
Posted on Sep 26, 2009
I have an Asko W600 front load washer that does not spin water out of clothes. It fills, washes, empties but does not spin- skips this part.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Asko W600
My asko w6222 shows F3 and stops. What is an F3 - some kind of error?
Drainage error
If F3 is flashing on the display, there is a
drainage problem. Check:
• that no objects are stuck in the drainage
hose outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump (see the
"Care and cleaning" chapter).
• that there are no kinks in the drainage
hose.
After taking the necessary action, run the
Drain program or press the Door Opening
button (key symbol) to empty the machine. If
the problem persists, contact the Customer
Care Center at
1-800-898-1879
www.askousa.com
May 30, 2008 | Asko Washing Machines
What does f3 flashing mean?
F3 error code means your washer has not drained. To fix the washing machine error code is simple and straight forward. Simply remove the drain pump filter and slide the filter out and clean the debris inside. The filter in most cases is on the lower bottom panel. Simple depress the tab and fold the access door down. The washer drain pump filter is a white handle twist the handle to remove the filter. You may also find an article of clothing trapped down where the filter is like socks or change etc. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
Jul 08, 2011 | Asko W6222 Top Load Washer
F3 error message
Hi, Welcome to FixYa. The F3 error for an Asko washer indicates a problem with the pump or a blockage in the pump. Remove the pump insert/filter and clean it and check inside the pump and hoses thoroughly. Let me know what you find or if you need more help/direction. Good luck. Regards, Macmarkus :)
Oct 26, 2010 | Asko Washing Machines
Washing machine wont drain, door is locked, and cant get clothes out of machine, says F1 and F3 error. wat do i do?
sounds like a safety check is on. check the pump to make sure nothing is stuck in there. read the manual for checking pump on that Asko machine..
Oct 14, 2009 | Asko W6021 Front Load Washer
The washing machine stopped on the rinse (6) with an F-3. Now what do I do?
"F3" on Asko means the machine detected an interuption in the drain sequence. could be as simple as a coin or some other debris causing the fault, but it may be the pump is faulty as well. first things first.
**UNPLUG the unit from the dryer, or from the wall, which ever applies to your set-up**
in the lower left corner on the front of your washer is a "pin catcher/lint filter" for the pump (a pump insert asko calls it). unscrew this insert, clean out whatever is obstructing the pump and you should be fine to continue. unless the pump itself is at fault. **you will need to drain whatever water is in the unit into a drain, or pan thru the little drain line from the pump (refer to your manual if you have access to it).
hope that helps,
good luck
Sep 28, 2009 | Asko W6021 Front Load Washer
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
Fault code f3 on asko wm 200 washing machine
blockage in pump or the drain hose sink end if it under the sink
Aug 19, 2008 | Asko Washing Machines
We have a code F3 on our asko washing machine
Most likely a drain pump problem. Make sure there is nothing in the drain hose. Then it would be a bad drain pump
Jun 09, 2008 | Asko Washing Machines
F3 Error Message
The F3 error code relates to a pump problem Check pump trap and clean. Good luck!
Aug 25, 2007 | Asko W6441 Front Load Washer
Asko W6441 Front Load Washer Logo
1,067 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
