Question about Black & Decker Saws
Instead of cutting, my saw burns the wood and makes
Instead of cutting my circular saw burns the wood and makes a very wide cut does that mean I need a new blade or is it something else?
  • 376 Answers
Sounds like a very dull blade.
Posted on Jun 30, 2009
When cutting 7.5" laminate wood floor with 12" miter saw. When we cut, the very end of wood(1.25"at the same place on every piece). Does this mean blade is dull?
Hi Shaun:
Just a couple of things to try:
- Make sure the laminate is supported at both sides when cutting.
- Make sure the laminate is held firmly against the fence and deck when cutting.
- Do not "rush" the cut. Laminate is very hard and does not like to be hurried.
- Make sure that the correct blade (teeth) is being used.
- And yes, the blade has to be SHARP
Jul 25, 2015 | Saws
Tip
My Blue Laser
Ever wish you could make that perfect cut the first time with your miter saw or table saw ? Simple if you put a strip of wide blue tape on base of saw and cut the tape with your saw ! Now you know where the blade will cut, now mark your wood, move the wood and the pencil mark to edge of tape that you just cut and cut it. That simple and easy to calibrate verses the red lasers that come on some saws that to me never work right to begin with.
Valley2118
on Feb 19, 2010 | Saws
Circular saw spinning but not cutting wood
Does the blade actually stop when you try to cut or does it spin but not cut. If it is stopping, and the motor is still running then I am afraid you have stripped gears and will need anew armature and spindle gear (sometimes complete with spindle, sometimes a press fit with a woodruff key to locate it). If the motor is stalling then it would suggest that the field coil is faulty, but you would notice excessive sparking from one brush if this was the case. if you get major sparking from both brushes then the armature is probably faulty, or if you are lucky it could just be brushes wearing low and not making a constant contact.
If the blade is spinning and not slowing when you try to cut I would think it is either blunt or mounted the wrong way round.
Sep 21, 2013 | Worx Versacut Mini Circular Saw
How do u life up the saw sleeve (the thing u move to cut the wood) on my Kobalt 10-in 15-Amp Sliding Compound Laser Miter Saw
If your saw is completely intact, meaning no missing or damaged parts, the blade guard should rotate out of the way of cutting as the saw head is lowered to make a cut. You didn't give your model number but there should be a push rod or link plate from the pivot point on the base to the blade cover that pushes the guard out of the way as the head is pivotted downward. If you have the cutting head locked down to make sliding cuts the guard should be up and out of the way. If this isn't happening you may have broken or missing parts of the guard system.
Feb 17, 2013 | Saws
Saw stops when i start cutting 1/2 plywood.
If it actually binds and stops the motor...... it sounds like the motor is bad, the bearings are bad, or the blade is on backwards. If the motor keeps spinning, but the blade stops then the gears are bad or the blade bolt is not tight.
Dec 10, 2012 | Worx Versacut Mini Circular Saw
The saw is producing blue acrid smoke upon use. I am using a vacuum to evacuate the shavings, but the saw itself does not seem to be cutting the wood. I am using a hardwood and feeding it slowly into the...
check the blade, it sounds like it is burning the wood instead of cutting it. I would recommend using a carbide tipped blade for the hardwood. Let me know if you need more assistnace.
Sep 11, 2011 | Ryobi Saws
My saw will cut for 5 seconds and then the blade stops spinning. When I back the blade out it starts again and the process is repeated. It takes a long time to cut wood this way. What's the problem? Is...
I would suspect a combination of the two! You blade probably isn't sharp and your saws brushes are probably getting worn. The brushes are made of carbon and are pushed up against the rotor by a spring. As the brush wears down the spring doesn't put as much pressure on the brushes which means it will stop working when placed under heavy load.
Aug 11, 2011 | Rotary Professional Grade 7.25 Inch...
I can't get this saw to cut straight or square I
Band saws pull to one side on straight cuts, it's a function of the blade torque. My 14" saw pulls to the right. There's nothing you can do to stop this, you have to be aware of it so you account for it on free cuts and know to put your fence on that side so the wood pulls into the fence instead of away from it. Squaring the blade to the table is easier. Do not go by the tilt angle guide. First make absoutely sure all of your blade guides and bearings are properly alligned so they aren't pushing the blade out of line. Use a square to get it close then: using a 4" x 4" block of wood, make a light cut in the wood only deep enough to mark the wood from top to bottom. Turn the block over 180 and try to make a cut in the previous cut mark. If the cuts line up you're there. If you get a V or X you have to make adjustments to the table making sure you tighten the trunion locks tight. I had one of these, it's not a high end saw so don't expect a lot from it.
Aug 23, 2010 | Ryobi 9 in. Benchtop Band Saw
To get the blade guard on a Ryobi circular saw to stay up.
Blade guards are spring loaded so they will not stay up unless you hold it up manually
May 05, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Not cutting through wood. Cuts are diminishing.
Sounds like the wood your cutting through is to hard for your battery powered saw....try one with a cord they work much better, especially for hardwood's.
May 03, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
Saws Logo
198 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Ruben Bustamante
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
