Question about Watts Onan Portable Generator - 4000 , Model# 5500
I have an onan 2500 wt propane that shuts down when the air is turned on - Sprinter motorhome
  • Sheldon Dedek May 11, 2010
    Does it shut down all the time? Are you able to initially start the
    air conditioner, but upon restarting air conditioner, then generator
    shuts down? It is unusual for a propane generator to have sudden problems that are more common to gasoline gensets. 2500 watts does not give much headroom for other devices when starting an air conditioner. You only have a few hundred watts for everything else that might be turned on as well, including your power converter that charges batteries. If you turn off absolutely everything else (including power converter if you can find the breaker for it), does the air conditioner then run?
    Problem Solver:
  • 6 Answers
Gov and or carb out of adjustment, bad LP regulator
Posted on Aug 21, 2009
1996 Onan Propane 2500 Microlite Generator often will not start & dies when microwave is started?
Microwave ovens need to be connected to a separate, dedicated line.
Nov 28, 2013 | Grilling
Onan Propane Generator Problems
Is the generator coming up to proper speed? A cycles (hertz) (should be 60 in USA) meter will tell.
If it is up to speed, see if a UPS unit is made powerful enough to power the microwave. That will handle the initial starting load from the microwave.
UPS units are handy to power stuff while you are getting the gen going.
Nov 28, 2013 | Onan MicroLite Generator, 2500 Watts / LP...
1998 discovery motorhome turned on propane at tank no gas at stove.is there a another shut off valve
It can take a while for the propane to get to the stove. ( 20 seconds maybe ) All the air has to bleed out of the line first. Also , if you have 2 tanks , there could be a selector switch on the regulator where the 2 tank hoses come in , that has to be selected to the tank that you have opened the valve on.
Oct 03, 2013 | Cars & Trucks
I have a 06 2500 dodge sprinter and the fan control speed wheel isnt working. Settings 1-4 will not work. I can feel hot or cold air coming out of the vents while I'm driving but cannot adjust it.
I have changed the resistor 2 times for the same problem. Its under the hood behind the fan motor insulation.
Mine burned because of fan motor frozen & stuck in the winter. Solution is to let the engine warm up before turning the fan on.
Cheers, Brian
Jun 30, 2012 | 2006 Dodge Sprinter
I have a 1984 winnebago motrhome with a 6500nh rv onan generato runs getting power on the line but none in the motorhome
Hooked in to motorhome via automatic switchover, or does the power plug of motorhome have to be plugged in to receptacle at or near generator?
Mar 15, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
I have an Onan 2500 LP generator. What is the red knob for?
That knob should be to bring pressure up and down with 0 being off or the lowest range of the regulator. This regulator is adjustable for different applications apparently.
Jan 21, 2010 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
246 people viewed this question
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
