Question about Dometic Rooftop RV Air Conditioner
Blower wont come on
My duo therm kicks the breaker sometimes. but when it comes on the blower never tries to come on. the low pres line gets nice and cool.my wife is very sick person and has lung trouble. thanks for your help.
bill
  • william darter
    william darter Aug 23, 2009
    it kicks the breaker the second that i turn the breaker on. and the fan will not come on. sometimes the compressor will come on. and sometime kicks breaker.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
If the blower never tries to come on, then that is why it is tripping the breaker. If the breaker is tripping while the entire unit is running, try cleaning the condenser coil. Go on top of the unit and remove the AC shroud. With a water hose, gently rinse the condenser coil out from the rear. Continue doing this until the water that flows is clear. This should help with the breaker problem, if it does not, then the fan motor is overheating and causing the amperage to go up. What size of breaker is the unit on? Does it trip mainly on hot days? If so then it is the fact that the condenser is dirty.
Posted on Jul 04, 2009
Compresser will not start up Fan runs but compressor just kicks on and right back off
Low freon. As soon as the compressor starts the low pressure side drops below operating pressure. The freon carries oil that lubricates the compressor. the low pressure switch shuts it down to protect it.
Aug 24, 2014 | Dometic Rooftop RV Air Conditioner
Why does AC Duo-Therm thermost throw the breaker and needs set to approx 55/50 to run ?
`Try changing the breaker some times they get weak and will trip at start up. Also check for bare wire shorting out. Then check capacitor then fan motor spin blades to see if they spin easy and that bearings are not bad.. make sure all connections are tight with no corrosion. These problems show up more with short cycling then with long.
Jun 27, 2014 | Dometic Rooftop RV Air Conditioner
Duo therm ac trips breaker
When compressor for cool tries to kick in, or even when fan only used?
Try it on fan only, not cool, then try cool and if you hear it sort of "moan" then breaker trips, that's compressor trying to kick in. Make sure you have sufficient power coming in to trailer as well, without long extension cord. Get back to me, then I can tell you which way to go from there.
Apr 20, 2012 | Heating & Cooling
Duo Therm AC Not Cooling
most likely a thermostat problem most rooftop air units fan will blow cont. and compressor cycles
Jul 26, 2009 | Heating & Cooling
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
Have duo-therm ac breaker will kick when temp outside above 85d- most of the time run fine
when it is above 85deg. it will run the freon pump. causing the unit to pull more amps for a longer time. try replacing the breaker with a new one of the same raiting. if this fixes the prob. the have a nice day. if not then you need to get it to a repair center and have it checked by a tech.
Jun 27, 2009 | Dometic Rooftop RV Air Conditioner
My Duo Therm Runs good until the outside Temp. Reaches about 75 dregees Then starts kicking off the braker. What would cause this?
Too many things on the same circuit. Try turning everything electrical off but the ac and see if it stops tripping the breaker.
Jun 08, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
147 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
