Do I fill it with Water?
I have been given a Homebase air cooler Model MF-588A but i have no user instructions, the top panel opens and there are 2 icepacks inside which i have now frozen but do i have to fill the compartment with water, there is a large compartment in the top wwith a small one to the side of it and a window at the bottom with Max and Low on it that makes me think it should have water in it
I don't know why but I kept the instructions -
Instructions are:
Lift the top cover and fill the smaller compartment with water - takes 11 litres from empty. Water level is seen on the window to the front.
Ice packs are placed in the larger compartment (That is all this compartment is for - Not to be filled with water)
Posted on Jun 26, 2010
  • dark_rah
    dark_rah Jun 16, 2012
    Hi i just wanted to make sure, the icepacks go on the top? and what is the use for the side drawer? thanks
I did not have instructions with my second hand one but you can see how it works you must fill it up with water first from the top the small compartment takes the water straight to the tank, the large compartment does the same but first soaks the cloth inside, now if you took off the filter panal off the back you will see the cloth..switch it on the cooler and press the two icey breeze buttons now you can see at the back the cloth is moving keeping it wet from the tank of water making a cold breeze.
Posted on Jul 28, 2009
Do I need ice packs for cold air? Where can I get them?
Posted on Aug 18, 2012
I want to download a printable version of User Manual for Air Cooler & Heater MF-588AD
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Oct 21, 2016 | Cameras
How to take the top off mf my bosttitch 6 gallon pancake 150 psi air compressor
the should be a bunch of phillips head screws and 2 flat heads deep inside it
unscrew and it will come apart
Jan 04, 2014 | Stanley Bostitch 2hp 6gal Air Compressor...
Air cooler
What is the model number?
Oct 20, 2012 | Refrigerators
Would like tou know how to use my air cooler model mf 588a
air cooler mf-588a non ho il manuale di istruzioni e vorrei sapere come funziona. GRAZIE MATTEO
Jun 20, 2009 | Heating & Cooling
HELP l need instructions for Homebase LF320 air cooler
I have the same unit, also given to me, and there really isn't much to it. Remember, it's an 'air cooler, not an air conditioning unit. Works fine as a floor standing fan on L, M and H settings (lo, med and high) but, if you want the air to cool slightly, freeze the blue ice packs and then put them in the base of the unit and top up with cold water until the level indicator on the front says full (red ball hits red arrow, like in a kettle). Then, turn on as normal and run the 'Cool' function along with your desired fan setting (L, M or H). I tend to add a few extra ice packs. The 'Cool' setting drags a fiber membrane into the water and over the intake surface, thus cooling the air slightly. Nothing like real air con but better than nothing on a day like today. 'Swing' throws the air around a little and 'Mode' gives you bursts of air, and that's about it to be honest...
Apr 07, 2009 | House Brand Dryers
We have 30 gtc model air cooled chiller problem is water intered in the compressor but we opened the cooled and given the pressure to the cooler but there is no leakage in the cooler then from water is...
you are going to have to try to dry out the refrigerant by replacing the drierd and pulling a good revaucuation on the unit after you replace the drier that are in the refrigeration lines .
Mar 21, 2009 | Carrier BM23S-2 Refrigerator Beverage...
I want the bottom to be reds and top to be whites
I don't think you'll be able to do this without some modifications to the unit.  The wine cooler is designed to blow cold air into the bottom section, and the top section cools down by spillover of cool air flowing between the glass door and the temperature control panel.
I guess if you could figure out a way to turn the panel that separates the top from the bottom you could make it work.  You'd have to switch the temperature sensing leads on the thermostat inside that panel(that would be pretty easy) and you'd probably want to flip the LED indicators so they read right-side-up.  The main issue would be that the screw holes for mounting that separator panel are all on the bottom, but when you flipped it, they would be on top with no holes in the walls to screw them into.  If you are willing to do that, you might be able to make it work as you would like.
Good Luck!
Dec 27, 2007 | Danby DWC283BLS Wine Cooler
Fujitronic FH-776 air cooler
I have looked all around sir, Cant seem to find one.
Aug 03, 2007 | Fujitronic FH-776 2.11 Gallon Humidifier
Heating & Cooling Logo
5,351 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
