Question about Sanyo DS31590 31" TV
My sanyo ds31590 31 has a black picture with a thin white line in
When turned on, my sanyo DS31590 31" tv has a black picture with a thin white line in middle.how do i fix it?
  • 105 Answers
Check the voltage at vertical ic must get 24volt dc then replace the IC that all
Posted on Jul 01, 2009
Sanyo 31'' Standard Def CRT TV
This is a vertical problem that can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages present inside hte set even when unplugged. If you wish to attempt this repair, please update this and confirm your model number as DS31590 and I'll supply additional details and instructions.
Dan
Feb 24, 2009 | Sanyo DS31590 31" TV
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
Ps2 hookup to a sanyo 42in. flatscreen 1080p
Need to resolder the parts inside they call it CRYSTAL to make the color cameback. It happen mosthly bcoz of the old of the tv.
Apr 23, 2008 | Sanyo DS31590 31" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Tv has no picture, has sound
this is a job for experienced tech need troubleshoot high voltage to picture tube 25 to 30 thousand volts
Mar 27, 2008 | Sanyo DS31590 31" TV
Sanyo ds31590 picture's very dark and red
sounds to me that your picture tube needs rejuvenated.
You will need to get it done by a tech.
mechanical doesn't mean a thing when it comes to electronics.
Mechanics when working on electronics, end up costing more damage when you end up taking it to a tech.
Oct 23, 2007 | Sanyo DS31590 31" TV
Sanyo DS31590
after replacing h-output, picture too wide. found c416 and c417 bad. looks fine, but checked bad on cap checker.
also replaced L413 L416 D407
also check caps in driver circuit and h-width circuit.
fixed mine.
good luck
Aug 28, 2007 | Sanyo DS31590 31" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Sanyo DS31590 31" TV Logo
518 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
