Question about Vehicle Parts & Accessories
My 03 sonata alarm keeps going off - Vehicle Parts & Accessories
  • 3 Answers
TIME FOR A NEW CAR BATTERY.
Posted on Jun 30, 2009
How do you get a 2004 hyundai sonata to start after new battery was installed causing the alarm to keep going off.
have you tried locking and unlocking the car with the remote. How about locking and unlocking the drivers front door with the key?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 02, 2015 | Hyundai Motor 2004 Sonata
03 laguns estate boot saying open and its not and my alarm keeps going off when i lock it
Sounds like the switch that is activated when the boot is shut is not being depressed enough or is broken.
Aug 13, 2014 | Vehicle Parts & Accessories
I have a 2003 hyundai sonata and i dont have the remote for the stock alarm. My alarm keeps going off and my car wont start. I bought a new battery and even tried the key in the door still no luck.....
The 2003 Sonata is equipped with a 'starter KILL' burglar alarm system with disables the starting system (using a N/C 'contacts' configuration instead of a N/O contacts configuration). N/C=Normally closed, and N/O=Normally open contacts. When the alarm goes off with a MY Sonata, the only way to DISARM it is with the key fob (remote) originally programmed for it (unless you purchase a new remote & have it programmed for the vehicle at an authorized Hyundai Service Department). NOTE: So long as the keyless entry & burglar alarm system is functioning/operating normally, the alarm will keep going off and the STARTER KILL function will still prevent you from starting the vehicle. One option is left without purchasing a new remote and having it programmed.
1. When the alarm goes off, get into the vehicle and insert the ignition key into the ignition.
2. Turn the key to the 'RUN' position (NOT the ACC position) and wait for the alarm to STOP (usually about 3 to 5 minutes).
3. The engine should then start using the ignition key.
If this procedure doesn't work, the problem will need further diagnosis by a qualified/certified Hyundai Service Technician.
Hope this helps
Aug 27, 2011 | 2003 Hyundai Sonata
Alarm keeps going off on TUscon
Have you tried reducing the alarm's sensitivity? There should a control knob that allows you manage the sensitivity of your alarm. If this is a sudden occurrence, I would suggest you get your battery test.
Jan 15, 2011 | 2006 Hyundai Sonata
Car wont start
Sounds like you have a shorted wire causing a drain. I recommend disconnecting the alarm all together which should stop the short so battery can remain fully charged.
Jul 09, 2009 | Hyundai Motor 2002 Sonata
Alarm goes off when trying to jump
keep putting the earth on and off it might take a lot of times to cause it to reset you need charge in the battry and has to be done fast till you here a chime
Apr 21, 2009 | 2005 Hyundai Sonata
Alarm Issues
I have been having this same issue for the past 6 months. So far no one can give me an answer that solves the problem. I have done several things unsuccessfully 1) changed the battery (still happens) 2) flipped the valet toggle switch under the steering column (still happens) 3) I lock the doors using the automatic lock button on the driver and/or passenger door (the alarm will not self-activate and go off, but this still doesn't solve the root problem with the alarm)
Mar 28, 2009 | 2005 Hyundai Sonata
Alarm won't turn off
There is a silver toggle switch on the lower dash on the left side...it's called a "valet switch" shuts the whole system off!! Took me 3 months and 100's of calls to dealers etc....lol
Dec 16, 2008 | 2000 Hyundai Sonata
My 2006 hyundai sonata alarm keeps going off
One word:
Dealer.
Next time just disconnect the battery until you get it towed as this is a warranty item. I'll bet some wondered if this was a prank question like I did, right?
Nov 17, 2008 | 2006 Hyundai Sonata
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
