First you need to know if your phone is compatible with whatsapp. Open the Play store and search for whatsapp. At the top does it say that this app is not compatible with your device. It will be in a black bar. If it doesn't say that then you should be able to install it. If it does then you are out of luck. It will not work on your phone.
SOURCE: i have samsung b7722 duos
I am unable to open messages in my samsung B7722,it's showing scanning failed...
SOURCE: how to install applications in
you may copy application (.jar) file to card memory which you will see in folder: other files. Then tap on the file name. This will install the application and you can access it in 'Games + more'.
SOURCE: I want the email settings
samsung duos B-7722 email setting----------------
smtp server- smtp.gmail.com
port - 465
ssl - yes
incoming server - imap.gmail.com
port - 993
email adress---------------
password------------------- - durgesh pawar
SOURCE: LG KP 500 FORMAT CODE
To hard reset an Lg Kp500, you need to press 1809#*500# and then choose factory reset.
For the Samsung phone:
Some codes that I tried and worked successfully are:
Software version : *#1234#
Hardware info : *#2222#
Battery info : *#0228#
Master Reset : *2767*3855#
The last code is the master reset.
Good luck!!
