Question about RIM BlackBerry Bold 9000 Smartphone
Bold speaker volume
The volume for my ringer / speakerphone has become quiter with time. i discovered that when I remove the back of the phone it is several times louder than with the cover on. Clearly over time the back cover somehow squeezes or inhibits the performance of the speakerphone / ringer. is there a fix?
  • 541 Answers
Check if there is any dust in the speaker
contact service center
Posted on Jul 09, 2009
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
Pebble ringer inop
Does it have a speakerphone function, does that work? It would seem that the second speaker is malfunctioning. There is usually seperate speakers for the earpeice and for the rigner/speakerphone. You could open the phone and make sure the speaker is sitting correctly, it could have rotated off it's contacts. But you may have to replace the speaker, possible found on eBay.
Mar 20, 2008 | Motorola Mobility PEBL U6 Cellular Phone
BlackBerry bold 9700,its speaker phone not working,ringtones and music not heard,but if i put it near ear from back of the phone then music is heard.Please solve as this is my new phone
Your phone is set on handset mode.While playing music,press the blackberry button and select the activate speakerphone option on the list.This would work for you.
Mar 26, 2011 | RIM BlackBerry Bold 9700 Smartphone
The speaker volume on my blackberry bold is very low
the problem came from hardware, a poor speakerphone contact. If you press on upper part of your bold, the ring volume will be increased.
So, the workaround is to insert between batery and backcover a folded piece of paper to press the upper side of phone.
vincentvince, you are a little bit too ...
Dec 03, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry bold 9000 speakerphone doesn't work!
Guys- I have had the same problem with my speaker not working and it comes down to the spacing inside the phone. Some people have resolved the problem by placing a small piece of paper or credit card between the phone or the battery back. I actually took the back cover off, the battery off, and then unscrewed the 6 tiny screws to take the back of the phone off. You'll then see two small pins that act as spacers to keep the phone back off of the speaker and you can gently bend them upward a bit more and this totally worked for me. I noticed after I was using a leather pouch to hold the phone, the only way to take it out was the pinch the phone on that area, and was thus "smooshing" these pins down and not giving the speaker the appropriate spacing. You'll void your warranty by doing so - but you should be able to fix the problem.
Aug 04, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Ringer and speakerphone not working
a lot of the system volumes were put back to default. I only realized this when I downloaded the "Audio Manager Widget". Then I found that I apparently missed a couple volume settings.
also It might be due to the In-Call volume. The only time you can adjust the In-Call volume is when you're in a call (duh!). So, I called my voicemail and put it on speakerphone just left it all the way up and now I can hear the dialpad tones again!
also I think it was swapping from vibrate to full volume when I received an SMS (or was doing multiple things at once).
All sound stopped working on the device. It's an Dream from Optus.
try a quick reboot.. that shud fix all the problems though
if all the above moethod fails... its time to call the manufacturer....
good luck
Jul 08, 2009 | HTC G1
My blackberry bold speaker power loss
open the back cover, there is a white soft thing under the flash cover. push it a little bit with a tooth pick or a sharp knife, it should increase the volume dramatically.
Jun 18, 2009 | RIM BlackBerry Bold 9000 Smartphone
My blitz's speaker phone wont work. and the open/close, on/off, and ringtones, wont work... help! ive gone thru all sound settings and everything is "on" i can hear my calls thru the regular handset...
Try these couple of things:
The speakerphone feature lets you hear audio through the speaker and
talk without holding the phone.
  1. To activate the speakerphone while in answering or calling modes,
    press the Navigation Key to the right.
  2. The phone returns to normal (Speakerphone Off) after ending a call
    or when the phone is turned off and back on.
To adjust the ringer, key tone, voice call and speaker phone volume levels:
1. Press left soft key [MENU] (7) (1) (2).
2. Select the type of volume you wish to adjust.
3. Select the desired volume level.
4. To confirm, press OK.
Let me know if this works for you or if I can help you with anything else.
JimmyC
Jun 13, 2009 | UTStarcom Blitz Cell Phone
AT&T 926 Corded phone
check for a button or sliding switch on the side,top,or bottom for the ringer on/off, [ some phones even have this switch on the back ] as for the speakerphone, you may have to push the speakerphone button, then put the handset back on the cradle for the speakerphone to work.
hope this helps.
wg
Feb 13, 2008 | AT&T 962 Corded Phone (A21076)
Programing
Here are some suggestions Volume You may adjust the ringer, speaker, handset and headset volumes independently with the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined settings which can be adjusted to individual taste. You will hear an error tone when the maximum or minimum volume level is reached. During volume adjustment, a ?dashed line? icon shows in the display. Adjusting the Ringer Volume Press the VOLUME ^ or v button while in on-hook mode. And/or 1 Selecting a Ringer Tone You may select the ringer tone for each line independently. You may choose to turn the ringer off or select one of the four available ringer tones for each line. 1. Press STORE. The red indicator blinks indicating unit is in Store Mode. 2. Use the number pad to select a ringer tone 0 through 4 (selecting 0 turns the ringer off). 3. Press STORE and then press the desired line button. NOTE: The line indicators continue to flash for incoming calls even with the ringer disabled. You may not select the same ringer tone for both lines. Checking the Ringer Settings Check the setting or each ringer (on, off) by pressing STORE, followed by LINE 1 or LINE 2 button when the phone is on the hook. The ringer setting of the selected line will be shown in the display. If there are any further questions or comments please post here. Please rate this solution through fix-it. Thank you.
Jun 23, 2007 | GE 29485GE2 Three - Line Speakerphone w/...
RIM BlackBerry Bold 9000 Smartphone Logo
671 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
