Took the fan face off to clean; the blades also needed cleaned. Two screws and blade assembly came right out. Went to put blade assembly back on and I found two small nuts laying on the counter and I have no idea where they came from. As a result the blade assembly is not secure. I guess I need some kind of "burst-out" drawing to see how the parts go back together.
SOURCE: Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
Posted on Jan 04, 2009
SOURCE: how to open fan to clean blades honeywell model
first remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Posted on Feb 08, 2011
Jun 25, 2015 | Honeywell HT-800 Table Fan
Aug 21, 2013 | Cars & Trucks
Sep 22, 2011 | Windchaser 16 Oscillating Stand Fan, With...
Jul 01, 2011 | Honeywell HT-800 Table Fan
Aug 12, 2010 | Honeywell HV-180 18" Commercial Grade...
May 28, 2010 | Honeywell HV-180 Floor / Box Fan
Apr 15, 2010 | Honeywell Dryers
Jun 08, 2009 | Dryers
Jan 04, 2009 | Honeywell HV-180 Floor / Box Fan
Sep 05, 2007 | Honeywell HT-800 Table Fan
Aug 07, 2014 | Honeywell HV-180 Floor / Box Fan
138 people viewed this question
