Question about Compaq Armada M700 Notebook
Wrong Volume Running XP Pro and when I turned it on yesterday there is a message "The wrong volume is in the drive. Please insert volume 0108103001222 into drive E. I do not have this computer on the internet as I use it for pictures only. Thanks
  • Dinasaur 45 Nov 15, 2007
    Although I did not have the CD that was being referenced or could not identify it I tried the last one I had used to no avail. I was able to correct the problem with a return to a previous configuration with system restore. I should have tried that a week ago. thanks for the help.
  • Anonymous Dec 26, 2007
    the wrong volume is in the frive. Insert volume SBC Yahoo DSL into drive E
    Problem Solver:
  • 6 Answers
It looks like your computer is trying to access a cd in your CD rom drive. I may be completely wrong on this, but this is from my past experience. So once you put that CD in that drive its ok and you let it do do what its trying to do, then after that you take the cd out. If E is not your CD drive, let me know.
Posted on Nov 12, 2007
Only half the volume on the left channel of the mixer. Why? :(
Does the left meter do the same thing? If the meter matches the right one, I would suspect the volume potentiometer on the powered speaker. Try exercising the volume knob. There might be some oxidizing on the potentiometer.
Oct 25, 2017 | Allen & Heath Xone-22 2 Channel Dj Mixer
I AM IN THE PROCESS OF REMOVING A PROGRAMME A POP UP HAS APPEARED SAYING THE WRONG VOLUME IS IN THE DRIVE. PLEASE INSERT VOLUME CDA- DEFAULT-FULL INTO DRIVEE
I suspect there is some unwanted programs in your computer that is causing this problem.
You need to do a manual virus check on your computer else do a system restore
Any doubts you can contact a technician through the website
www.thebestpcdoctor.com
Toll Free: 877 407 8229
Aug 27, 2011 | Acer Aspire™ T180 PC Desktop
Volume icon in taskbar
You experience one of the following symptoms on a Windows XP-based computer:
* The Volume icon is not displayed in the notification area at the far right of the taskbar.
* When you try to add the volume control icon to the notification area, you receive the following error message: "Windows cannot display the volume control on the taskbar because the Volume Control program has not been installed. To install it use Add/Remove Programs in Control Panel. "
Therefore, you cannot start the Volume Control program and cannot adjust the volume and sound level settings of your computer.
There are two possible causes of this problem:
* The Volume icon has not been added to the notification area of your computer. (The Volume icon is not displayed automatically when you first install Windows XP.)
* The Sndvol32.exe file is damaged or missing.
Solution:
Method 1: Add the Volume icon
To add the Volume icon to the notification area of your computer, follow these steps:
1. Click Start, and then click Run.
2. Copy and paste or type the following command in the Open box, and then click OK:
mmsys.cpl
3. Click to select the Place volume icon in the taskbar check box.
4. Click OK.
If the Volume icon is displayed in the notification area of your computer, you are finished. If you cannot add the Volume icon or if you receive an error message when you try to add it, the Sndvol32.exe file might be damaged or missing. Go to method 2.
Method 2: Save a new copy of the Sndvol32.exe file on your hard disk
If the Sndvol32.exe file is damaged or missing, you must extract a new copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer's hard disk.
Prerequisites
This method requires you to have your Windows XP installation CD.
To extract a copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer’s hard disk, follow these steps:
1. Insert the Windows XP CD into your computer's CD drive or DVD drive. Press and hold the SHIFT key as you insert the CD to prevent it from starting automatically.
2. Click Start, and then click Run.
3. Copy and paste or type the following command in the Open box, and then click OK:
cmd
The command prompt opens.
4. Type the drive letter of the CD drive or DVD drive, type a colon, and then press ENTER. For example, if your computer’s CD drive is drive E, type the following, and then press ENTER:
e:
5. Copy and paste or type the following, and then press ENTER:
cd i386
6. Copy and paste or type the following, and then press ENTER:
expand sndvol32.ex_ system_root\system32\sndvol32.exe
Note: system_root is the path and folder name where the Windows system files are located on your computer. This is usually C:\Windows. If the folder that contains the Windows system files on your computer is C:\Windows, type the following, and then press ENTER:
expand sndvol32.ex_ c:\windows\system32\sndvol32.exe
Note There is a space between "ex_" and "c:\windows" in this command.
7. Type exit to exit the command prompt, and then press ENTER.
8. Verify that you can start Volume Control and that the Volume icon is displayed in the notification area (if you selected this option in method 1).
Hopefully the Volume icon is now displayed in the notification area.
Jul 18, 2009 | Computers & Internet
I have an erroe message I can't get rid of.
hey buddy this is the disc problem ...but some time dvd or cd drive can not read the disc properlly..and give u this erroe. that's mean ur cd or dvd lens get very very dirty..first try to clean it with the help of cd dvd lens cleaner... if the same erroe is come again then u need to change ur lens..or ur drive..
Jun 06, 2009 | Compaq Armada M700 Notebook
Gowthaman
Check if the jumpers on the hard disks are in the right position.
Apr 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have an error message from windows
If you still have the quick books pro cd I would place it in the drive and see if you can satisfy the machines need for this info.
Mar 12, 2009 | Microsoft Windows XP Professional
Logitech quick cam
All seems fine on my laptop , sound ,volume ,ect . the problem is i have a picture of myself on my PC and the person i am talking to but they have no picture of me ,,,i dont know what is wrong . Can any one help . Laptop is a Touchmate running via wireless router .
Sep 26, 2008 | Logitech QuickCam Pro 5000 Webcam
HD does not show up on desktop
is your volume NTSF then use any software to mount the volume !!
Mar 03, 2008 | Fantom Titanium Hard Drive
Compaq Armada M700 Notebook Logo
811 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
