Question about Universal Remote Control DIRECTV Universal Remote Control
I need to reprogram my rcr317w remote contact with manual
I can't get the instructions to change the TV channel to channel 3 so I can use my other components to play on my television. Please include instructions oh how change the tv channels so I can view channel 3.
  • 158 Answers
Turn the tv on. Hook up your components, turn them on, go in to tv menu and auto program the stations. It will see that there is a signal on channel 3 and lock it in for you.
Posted on Jul 01, 2009
  • Pam Hunt Nov 25, 2011
    can you do this without a remote?
Hi My matsui tv 1409T remote died (due to battery leakage!) so I have got a signalex universal remote as a quick fix replacement. I have set the remote to switch the tv on/off, change channel and adjust...
1) Change the batteries by alkalines
2) Retight the springs contacts with plyer for better contacts.
3) clean the contacts with special spray contacts.
4) Downloa the code or proceed with your instruction manual.
5) If the problem persist, you must return you remote control and buy other from Radio Shack I am recommending.
God bless you
May 14, 2012 | Televison & Video
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
Toshiba CF32G50 32" TV - wont turn to channel 3
try entering the channel directly via the remote by pressin"03" if that fails check to see if your cable box has a 3/4 switch on the back. if so set it to 4.
The main problem however, is that the TV needs to have the channels reprogrammed by following the instruction manual and/or on screen menu.
Sep 19, 2009 | Toshiba CF32G50 32" TV
Tv remote
go here www.remotes.com they will have the info you want!
please rate this answer
thanx
Jan 17, 2009 | Televison & Video
Manual buttons on set will only accept 3 channels
found solution by holding down both volume buttons at same time which enables on-screen menu allowing to select channel auto program
Dec 07, 2008 | SansuiS3275 TV
Reprograming
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 20, 2008 | Philips Televison & Video
Please help!
Hope this helps :)
Jun 06, 2008 | Philips Televison & Video
Manual
Hope this helps :)
Jun 01, 2008 | Philips Magnavox Learning Universal Remote
I changed batteries in my remote and i cant figure out how to reprogram it
Hope this helps :)
May 13, 2008 | Philips Universal PH301S Remote Control
Televison & Video Logo
157 people viewed this question
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
