Question about Garmin nuvi 200W GPS Receiver
Keyboard is missing the letter "T" in US English mode
Touchscreen keypad missing letter the letter T for the US English characters - the key is there but appears blank and pressing that blank key doesnt produce any character when typing - just seems like a dead spot. That same spot on the touchscreen does appear with the proper key and produce the correct character for all other language sets. Have already powered down, unplugged, and restored original factory settings without any resolution.
  • tomheckman Jun 30, 2009
    Thanks for your response, but I'm not sure I understand what you're saying. You indicated that this is a problem with the factory settings, but the unit worked fine for over a year before this issue emerged. You've suggested getting it repaired, but I dont understand what the physical repair would be - the touchscreen works perfectly except for that one letter in the one character set. To me, it seems more like a SW issue, but I don't know how to reload that.
    President:
  • 1,383 Answers
Check this likn and downlaod firmware then uypdate your gps if then still cmes problem then there is your touch screen hardware has issue.
Posted on Jul 01, 2009
    President:
  • 392 Answers
That is the problem with the factory settings of the english characters, get it repaired , the software has to be installed again. This is the only solution.we cannot solve it on our own, because if we do anything wrong the whole software may get damaged, so get it repaired and install the new softwate.
hope this helps.. please rate my answer.
Posted on Jun 30, 2009
I have a problem regarding my lg x110 notebook. some keys are not working properly like the letter g on the keyboard, when i hit the letter g it appears letter c on the monitor same as letter t and z and...
Examine your keyboard for any build-up of dust, dirt, liquids or other particles that could be causing the keys to type the wrong characters. Allow any loose dirt to fall out by inverting and shaking the keyboard lightly.
Confirm that your keyboard is set to the English language. Go to your control panel and click on the "Regional and Language Options" icon. If the setting appears to be in a foreign language, change it to English/U.S.
Check if your number lock key is on. If so, depress the key to disengage it.
Run a character key test by using the Microsoft Keyboard Diagnostics (MSKEY) program. While in the MSKEY program, hit several keys to make certain that they are the same keys that are identified in the MSKEY window. To start MSKEY in Windows Vista, select "All Programs>>Accessories>>Run" from the Start menu. Type "mskey" in the box and depress the "OK" button. Start MSKEY In Windows XP by clicking on "Run" from the Start menu. Type "mskey" in the Open box, then hit "OK." Depress either "PS/2" or "USB" to apply it to your type of keyboard hookup. MSKEY software is only available with Microsoft IntelliType version 1.1 or later.
Remember to clean your keyboard regularly to keep it free of dust and debris.
Don't disassemble the keyboard because it may affect the validity of your manufacturer warranty!
May 08, 2011 | LG Computers & Internet
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
How do I get swedish letters on an asus keyboard?
You get special characters by using alt codes. That is, you press and hold the "alt" key while entering a 4-digit code using the numeric keypad (or, on a laptop, the keys that serve as a numeric keypad). When you release the alt key the special character appears at the cursor location. This page lists the characters and corresponding code.
If you are using an application like Microsoft Word, there may be an "insert special character" command available. Then you can pick the character from a table instead.
Mar 04, 2011 | Computers & Internet
What is the keyboard combination for Ñ in a
Alt+0241
On Windows, the Alt key functions as a modifier like the Shift key. To make special characters, hold down the Alt key and type in the numbers from the numeric keypad. Note that on the some small keyboards (e.g. laptop keybaords) the “numeric keypad” is found by pressing the NumLock key and then looking for the keys on your keyboard that double as numeric keypad keys when in NumLock mode.
Jun 23, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
My keyboard on my laptop replaces the letters with numbers and/or characters when i click them, like when i press "I" i get the number 5, or w, o, p, l, k, I get fancy characters
Go to the control panel first and check the Regional settings and languages icon. Look in there and make sure all the settings say either "English- United States or just United States.
If everything is correct there, hold down the Fn key and tap the Num Lock key, then try the keyboard again.
Oct 07, 2009 | Dell 0Y3740 Keyboard
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Blue characters on the keyboard when I type
It is a combination of key known as "Function" (Fn, for short). You have to press it and hold while pressing other keys showing the blue letters on it. The most common use is to make a virtual Numerical Keypad on laptops, so you can perform calculations. To be back to normal mode, you need to press FN+F8 (or the key with the Calculator icon).
May 28, 2009 | Compaq Presario R3000 Notebook
Keyboard will not work
Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Let me know if this works for you, if not let me know.
JimmyC
May 07, 2009 | UTStarcom Blitz Cell Phone
Garmin nuvi 200W GPS Receiver Logo
73 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
