Question about HP Office Equipment & Supplies
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
My hp color LaserJet 3700 can't print my new letterhead. It jams or stops printing every time with the message "remove incompatible transparencies" even though I'm just using a 70# uncoated premium letterhead paper. How can I run this paper through my printer without triggering this message? If I can't run this paper through my printer, I've just wasted a bunch of money printing new 8.5 x 11 letterhead.
    Novelist:
  • 125 Answers
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Posted on Jun 30, 2009
Hi My printer 2600n prints a shadow of the
if logo preprinted may not take heat if everything repeats check fuser
Jul 28, 2010 | HP Color LaserJet 2600n Printer
HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
Feb 17, 2009 | Office Equipment & Supplies
HP LaserJet 5550DTN jams at transfer unit
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | HP LaserJet 5500dtn Color Printer
HP laserjet 5000N - Paper jam under the cartridge every time try to print
Jan 03, 2009 | HP LaserJet 5000n Printer
DOCUMENT PRINTS IN RED
Do like this, go to File, Print, Advance and choose print as an image.
Or you can do like this. In printer properties color management add a new color profile.choose U.S. Sheetfed Uncoated v2, apply.
Dec 04, 2008 | HP Laserjet 2605 Printer
Blinking yellow light
I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
My HP Laser Jet (color) 1600 is printing color on pages with no color!!
the wastage part of ur pink toner is full a is dropping the powder on paper.get it cleaned to continue good printing.wish u success
Jun 04, 2008 | HP LaserJet 1600 Printer
LJ3700 page tops half- way through fuser. Bob
13.01.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. 13.02.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. these are areas that you mentioned and fixes to them http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478#A3 this is the link to all error codes for your printer you might want to print these out and keep safe
May 07, 2008 | HP Color LaserJet 3500 Printer
NEW HP LASERJET P3005
Paper keeps jamming under guide plate.....and buckels. Require to remove toner cart. and pull back spring loaded plate and remove jammed paper. This happens after printer sits for 1 day. If I can finally get it to print, it will continue to work.
Apr 24, 2008 | HP LaserJet P3005n Printer
Hp 4250 GHOSTING
Are you telling the machine that paper type is letter head or envelopes, It must be done, it changes temp of fuser to suit the paper type, no it is not a power supply problem change paper type to card stock/thick/letterhead etc to suit then machine will adjust temp to suit.. ie file, print properties paper type.
50.2 fuser error replace fuser.
Dec 06, 2007 | HP LaserJet 4250n Printer
454 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
