Question about Crate Blackheart BH15 112 Handsome Devil Guitar Amp Combo, 15W All Tube with Attitude
Can I connect a Tascam 788 to my laptop so that I can transfer songs to it and, if so, how? I have the tascam 788, an uno 1/1 usb midi interface and depending on the computer am running windows xp or windows vista. I only need to transfer 2 tracks off it.
  • 73 Answers
Yes, if you have "line out" from 788. You will need appropriate cables to attach to PC sound card.
Paul
Posted on Jul 09, 2009
I need a reasonably priced audio interface to use with a remote synth and a MacBook (Garage Band). Any ideas?
I would go for getting someone else to record at studio, means they have all the professional ideas to bring to the table, solve problems, but if your just playing around in home a small focusrite 2/2 should do you, with 2 inputs for left and right mono from desk, or also dual linking in two separate channels via xlr.
Dec 07, 2014 | Tascam FW 1884 FireWire Audio/MIDI...
Tascam 2488 neo mmc control
That seems to be in the midi time sync functions. In cakewalk under options find the midi settings and choose midi device. All of you clock and sync settings should be there. Also I think under the audio menu there are settings for folders and I think a tab for sync is there as well. I use Sonar, which is an upgrade of cakewalk but used cakewalk for a long time. I have it on another computer and will look later to see if I am forgetting something or remembered it wrong and let you know.
Mar 14, 2013 | Tascam 2488NEO 24 TRACK RECORDING...
Buying a used Tascam 788. P.O. lost the power supply. How can I get a replacement? Couldn't find anything on TASCAM site.
Hi, Provided there is a tag on the back showing the units model number, on that same tag should be the power requirements for it-buying a universal power supply, or even a used working one to another piece of equipment is acceptable as long as the polarity is the same. Polarity is located right next to where the power supply plugs into the unit. It will be a " circle with a dash inside it with a line connecting to a C looking symbol with a line coming out of it connecting another circle with a plus sign inside. " that is a typical outer ground/inner positive marking. a power supply will be marked the same. If they match the polarities are the same. Next make sure the power supply says the proper DC voltage and Milliamps or amps-Ma/A example: 2400Ma, 2.4a. I hope this helps and thank you for asking FixYa, good luck and don't forget to write back and let me know how I did, Prodzilla.
Apr 23, 2011 | Record Tools Tascam Dp02 8 Track Digital...
How to connect psr-3000 to computer
You can connect it with USB connection to your computer. It should be plug and play, but some drivers might be required.
You can connect it also via MIDI interface: - you will need sound-card with MIDI input connector, or you can use special MIDI device like M-Audio UNO.
Mar 07, 2011 | Yamaha Full-Size Keyboard
I have a Tascam US1641 USB interface and wanted to know if you can connect a Behringer 2442fx to it to use it as a mixdown control for my music in Cubase studio5.
The 2442FX has a built in usb interface so there is really no need to use the Tascam. Here is a link for you:http://www.behringer.nl/EN/Products/2442FX.aspx
Oct 19, 2010 | Behringer XENYX 2442FX Mixer
Tascam CD-GT1MKII is turning off and on by itself
are you plugged in or on batts as mine was on batts and they were low.
Jul 29, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
I want to know how to set up a master on my tascam dp02
first set the in and out points of song make sure your holding down the shift key while setting in and out points.then pres shift key holding down on it pres master key it should start flashing.then pres record play.good luck
Jun 11, 2009 | Tascam Music
Control midi program sampletude
The Tascam has no midi In,Out or Thru so the answer is No.
Apr 21, 2009 | Tascam 2488mkii 24 Track Recording...
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Jan 24, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Problem with the USB TASCAM 2488MKII
Do you have alot of drives connected to your PC?
You might need to go into disk manager and assign the TASCAM a dedicated drive letter.
And it could also be your USB port that you are going into, or the cable.
Dec 11, 2008 | Tascam 2488mkii 24 Track Recording...
Crate Blackheart BH15 112 Handsome Devil Guitar Amp Combo, 15W All Tube with Attitude Logo
275 people viewed this question
Top Crate Music Experts
Michial Gueffroy
Ben Armstrong
richie46
Are you a Crate Music Expert? Answer questions, earn points and help others
