Question about Maytag Washing Machines
What is the capacity of a Maytag Top loading washer, LAT4916AAE
What is the capacity of a Maytag Top loading washer, model LAT4916AAE
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
Krazytech
  • 725 Answers
SOURCE: Maytag Performa Large Capacity Top-load Washer
the agitator should have a SCREW, AGITATOR RETENTION that holds it on ..see brakedown. unless you are talking about the DISPENSER, FABRIC it should just snap on. let me know if his helps krazytech
Posted on Sep 09, 2007
  • 1028 Answers
SOURCE: How do you remove the
clips just under front edge and about 3-4 ins from corners press in with putty knife lift top remove screws on upper edge either inside just below top or along top edge
Posted on Aug 10, 2008
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune FAV6800AW Top Loading Washer Noise
Hello gwatson01,
Wondering if you could rate my clarification request as a solution? I joined this forum as a owner DIY’er to help other owners. The machine is just too expensive to junk and as you found fairly easy to work on. As a forum member as you I receive no compensation for my support to other owners. Thank you in advance for your support. Rich
My solution;
I’m an owner/DIY’er of the machine. Please take a look at this post and see if your mechanical noise may be coming from underneath the tumblers, maybe some coins grinding around under the tumblers. If you think it is take a look at the service manual link in that post. It will take you thru the tumbler removal process, see if you feel comfortable with the process, the manual does not call out a #20 Torx driver is required to remove the tumbler.
If you think the grinding noise is very metallic and not muffled by a tub of water the grinding noise may be coming from the transmission/clutch area and removing the machine front vertical cover will be necessary to better sound isolate the suspect area of the machine. Do you feel OK to remove the front panel? If so see this post.
The 1st link I sent you to shows that this owner had issues after the coin removal. I would also like you try a Spin Only cycle with no clothes in the wash basket. Can you let me know if that cycle runs with no noise? We can’t totally rule out an issue with the clutch/transmission components with the info supplied so far. To help you remotely diagnose this issue detail information is needed. Let’s try to sound isolate the grinding noise source location. Follow all safety rules in the Service Manual. If you don’t feel comfortable to proceed I would recommend you call in a qualified FAV6800AWW repair service for support.
Posted on Apr 05, 2009
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
I am trying to find out the cubic feet for my maytag heavy duty top loader washer model number LAT870588E
see this link to see the answer, I KNOW the model number isnt the same as yours but having been in the appliance biz for over 30 years i know both are the same capacity and only the features are differenthttp://wiki.answers.com/Q/What_is_the_cu_ft_capacity_of_a_Maytag_washing_machine_LAT8434AAE
Jul 18, 2011 | Maytag LAT2600A Top Load Washer
I just purchased a Maytag centennial washer. I just love it the Maytag products arethe best. Question I am using the HE detergents as the book suggests, however how much bleach do I use?
According to page 6 of the manual for the "3 cu. ft. Capacity Maytag® Centennial® Top Load Washer" and page 8 of the manual for the "Centennial® High-Efficiency Top Load Washer", not more than 1 cup (250 ml) should be used in either machine.
Also, it should be added to the dispenser cup on the front left of the machine - not directly to the wash as it will interfere with the detergents ability to clean the clothes.
I hope this helps & good luck. Please rate my reply. Thanks.
Apr 20, 2011 | Maytag Centennial MTW5800TW Top Load...
Where can I find the capacity load of my washer or how big is my washer?
acording to dealtime.com the Maytag Neptune FAV6800AW Top load washer has a volume capacity of 3.5 cu/ ft; or (Depth x Hight x Width) 29.25 in x 37 in x 27.25 in.
Mar 01, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Just trying to find out drum capacity of my maytag heavy duty super capacity 7 cycle washer. Please help
Check the tag where you find the model and serial number, they often list it there. Your owners manual should tell you as well. You might have to call whirlpool (maytag), I cannot find the capacity listed on the tech info. Good luck.
Sep 23, 2010 | Maytag LAT2600A Top Load Washer
My top load washer smells like moldy, nasty water
use some vinagar let wash
i heard deluted CLR works too, but delute it really good
Apr 18, 2010 | Maytag HAV2557 Top Load Washer
How to remove motor from maytag washer lat4916aae
some have screws that are at the bottom of the front panel and some just pry off..lift front cover from bottom swing out and up to release from top. motor is in left front corner. remove wiring and top cover and screw on plate mounted to floor in left most corner/front of plate. remove motor and plate. flip over and remove nuts holding plate to motor..install reversely.
Jun 13, 2009 | Maytag LAT3600A Top Load Washer
Washer stays in same cycle maytag lat4916aae
if you mean timer not advancing past a certain point...timer bad
Jul 31, 2008 | Maytag Washing Machines
How do I check washer specs?
They made this model apparently between 2002 to 2004, it is specified as 10kg capacity. If you end up getting it then here are some parts diagrams for the model that may come in handy; http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LAT9704AGE&mfgModelNum=LAT9704AGE&fkMfgID=1 I'm afraid i have had no luck with a manual, but this link shows an auction of one near you from a couple of weeks ago - you may get an idea of what people think and what it's worth http://www.trademe.co.nz/Home-living/Laundry/Washing-machines-dryers/auction-90916298.htm Maytag appliances are normally above average in quality, found nothing specific about particular faults with the model which probably means it is pretty reliable. You could also ask maytag - they may be helpful - please let us know the results if you try them; http://www.maytag.com/support/contact_us.jsp Hope this helps :)
Mar 24, 2007 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
371 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
