Question about Dell W2306C 23 in. HD-Ready LCD Television
Poor picture quality on cable input
Very snowy picture from cable input- signal from cable strong. TV has excellent picture from DVD input.
  • 909 Answers
Try swapping some cables around, like the skart lead from the dvd(if scart) for the cable one, if the picture problem swaps with the lead then thats the problem. If it doesn't try settings on the cable and tv, if the cable is sending nvbs signals and the tv is set to pal then this can also occur.
Posted on Jun 30, 2009
AOC PD4264 Screen fault
Extremely blue color temperature that cannot be adjusted; some false-contouring artifacts in dark scenes; no picture-in-picture; limited connectivity with just one DVI and no HDMI inputs.
If use as a TV monitor:
The number of colors you can display is controlled by the video card installed in your computer. In order to display more than 16 colors, the proper video card driver must be installed. Contact your computer or video card manufacturer to obtain the latest driver from them.
If you are watching standard-definition or Cable/RF signal on an HDTV, the picture may appear to be of poor quality. This is because the TV is designed for viewing HD or at least digital content. Your best bet would be to upgrade to a Dish Network HD receiver and connect it to the TV with an HDMI cable. Similarly inputting analog signal to TV from your DVD player will not appear to be of great quality. A newer DVD player would most likely have component video output which would look much better. To get even greater quality, an upconverting DVD player connected with an HDMI cable would look the best. You could also upgrade to a Blu-ray disc player, which is capable of playing HD Blu-ray discs as well as DVD's at higher resolution. A less expensive choice could also be a streaming media box. Hierarchy of inputs for good picture quality:
Apr 13, 2012 | AOC A42HD84 42 in. Plasma HDTV
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
When tv is turned on with cable channels picture is snowy. when dvd or vhs tape played through tv the picture is snowy
Try using the video inputs
Nov 13, 2009 | Televison & Video
Snowy reception on TV with LG DVB418
have you got both cables going into your video ?? if not you need a video splitter to input both the digital and analogue aerials then have a coaxial cable going to the tv
Mar 08, 2009 | LG DVB418 DVD Player
Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
Snowy picture
A snowy video indicates that your input signal is relatively weak. On the other hand, a noisy picture is when there are too much interference is super imposing on the video.
Snowy picture comes about when the signal coming in the RF INput (Ant/Cable) at the back of the unit is below a certain level. If this is the case, then it is not a problem with your TV but rather your aerial (antenna) or the cable from your provider. A way to verify that it is the ant/cable that is the cause and not a defective TV/tuner is to hook up an old VCR set to Ch. 3 or 4 to the RF IN of your TV using a short 75 ohms coaxial cable terminated at both ends with FP-5 connector. Play a known clear good tape and set your TV to Ch. 3 or 4 as the case maybe. If the picture is relatively clearer, better, then you have just confirmed that it is indeed your aerial or your cable (provider) that needs looking into. If on the other hand, the VCR signal is also snowy then chances are that you have a problem with the input stage of your TV including possibly your tuner.
For your aerial problem, antenna orientation or replacing with a higher gain antenna might help solve the snowy signal. For your cable problem, you have to call-in for service from your cable provider. If it is a TV problem, your best course would be to seek the services of a qualified TV technician since this involve electronic circuitry analysis, diagnosis and possible component replacements.
Additionally, you may try looking for any loose connection, loose grounding, broken wire or anything out of the ordinary in your connections.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 12, 2007 | RCA P52926 52" Rear Projection Television
Picture quality and sound
than the tuning coil of circuit,like 39mhz coil or other circuite related with I.F. and detection section coil or any p.f.will be damaged if it should b currect than replace the tuner
Mar 06, 2007 | Zenith Z46Z83D 46" Rear Projection...
Dell W2306C 23 in. HD-Ready LCD Television Logo
169 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
