Question about Microsoft Xbox 360 Console
My xbox wont show picture only sound
My xbox 360 is **** a turn it on, it loads up and no picture but i can hear the sound sum1 pls help!
  • 767 Answers
Just did one of those 1 hour ago
running great now
X clamp mod , it fixes so many problems.
Posted on Jun 30, 2009
My xbox 360 wont show a picture but it has sound
This is how to fix it. So here is how you do it. First i took off my hard drive on the 360. Then i pluged it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) i only say this because i didn't use the HDTV setting to fix it. then i pluged it into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on i took 1 towel folded it long ways and wraped it around my 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. i hope this will help u....pls rate...cheers...
Jan 05, 2010 | Microsoft Xbox 360 Console
My xbox wont show picture but i can hear sound. What do i do?
Try pulling the plugs a little for the vision and sound
Oct 24, 2009 | Microsoft Xbox 360 Console
My Xbox 360 will not show a picture you can hear the sound but there is no picture.
1) make sure the video cable is firmly inserted into the back of your xbox 360. Sometimes a loose connection will produce this result.
2) Check the end to your television set and make sure it is in correctly. Is this HDMI ??
3) Cycle the inputs on your tv until it gets back to your xbox 360 and see if the picture appears.
4) If you have this hooked up via HDMI, connect it through another method and go into the video settings in your xbox 360 dashboard and set them to auto detect.
Let me know if this helps.
Jul 28, 2009 | Microsoft Xbox 360 Console
Picture won't come up on my xbox 360.
When it is starting up push down y and pull the right trigger the console will reastart on default settings and u it will show the picture if this dosent work try when you hear the menu screen come up. It worked for me but now i have lines going acroos hopefully you wont have tht problem
Jun 29, 2009 | Microsoft Xbox 360 Console
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
please rate my solution :) thanks
May 31, 2009 | Microsoft Xbox 360 Console
Since your sound works, you know the xbox is booting properly.  Check two things: 1) try another television to make sure it's not the tv.  2) try another cable(from a friend?) to see if the cable is bad.
**Also, if the video settings were saved on an unsupported setting, it could cause the screen to not show video.  If you try these 2 things and you think someone might have saved bad settings, I recall a button combination you can use to reset certain things, and I try to help if it comes to that.
May 30, 2009 | Microsoft Xbox 360 Console
My xbox wont show on my tv,cant hear sound but no
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
May 12, 2009 | Microsoft Xbox 360 Elite Console - Black
Won't show the picture or sound
Here's one possiblility.
There should be a switch on the x box cable that goes from High definition output to analog.
Try changing the swith setting.
Jan 02, 2009 | Microsoft Xbox 360 Console
No Screen on the Xbox 360.
i would help you but i have the same thing my did that to but my xbox show me colors then it whent to black screen and says to call xbox/support
Oct 19, 2008 | Microsoft Xbox 360 Console
Please help me i was playing a game in my 360 when suddenly the picture just went out but i could still hear the sound know every time i turn it on its like the how do i fix it.
Over heating wont turn on
http://forums.xbox-scene.com/index.php?showtopic=599216
http://forums.xbox-scene.com/index.php?showtopic=606431
http://copronymous.com/wp-content/uploads/2007/05/fix-for-the-3rlod.pdf
Nov 03, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
209 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
