Question about Sony KV-32TW67 TV
WHAT IS A LCD
TECH JUST TOLD ME THAT MY LCD IS BAD OR LOOSE, WHAT IS AN LCD FOR MY BRAND OF T.V.?? ( SONY KV-32TW67)
  • 975 Answers
It means "LIQUID CRYSTAL DIODE" , AJ
Posted on Jun 30, 2009
LOST REMOTE ON A SONY TV MODEL KV-32TW67 HOW DO I USE BUTTONS FROM TV TO GET TO THE MENU PICTURE AND AUDIO NEED TO BE ADJUSTED DONT HAVE REMOTE HELP ME
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops
Oct 02, 2014 | Televison & Video
LOST REMOTE ON A SONY MODEL # KV-32TW67 HOW DO I USE BUTTONS FROM FRONT OF TV TO GET TO THE MENU PICTURE AND AUDIO NEED TO BE ADJUDTED DONT HAVE REMONTE HELP ME
If there is no 'Menu' button at the front panel of the TV, you should have a remote control to select the inputs. Most models of Sony TVs won't have this button.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Sony KV-36FS210 intermitted horizontal comes and goes nothing is coming up on self test. notice when tap lightly if facing tv on right side it stops. took back off just don't know what I'm looking for....
Sounds like a loose contact. Check all the solder terminals at the horizontal output as well as IC terminals, for any loose or dry solderings. Re-solder all the suspected solder terminals, by applying a little more solder, without making any solder-bridge short in between adjecent solder terminals.
Oct 11, 2013 | Sony FD Trinitron WEGA KV-36FS210 36" TV
My tv does not come on it is a 1998 sony kv 35v36
Most common problem with this set is Horz. Sweep transistor shorts; also two reg transistors in power supply and .1 ohm resistor near them.
It is sometimes caused when set shuts off and you turn it back on by bad solder connections at Horz. driver transformer.
To be honest, even with generic parts the repair will be well over 150 dollars--set may be too old to make this kind of investment in: some parts for it are no longer available and if you fix you run the risk something else may fail and the part be unavailable etc.
I do not like giving bad news--these were great sets but I am being truthful here.
If this told you something you did not know rate this solution as very helpful as I do it here for free.
SD TECH
Aug 21, 2010 | Sony KV-35V36 35" TV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
HORIZONTAL LINES
You are seeing retrace lines, Either you have a bad picture tube or your screens control ( on the flyback transformer) is set too high.
On some sets the focus and screens control is accessible without taking the cover off. If so there will be 2 small holes on the back of the set labelled "screen" and "focus"
insert a small screwdriver into the screen control and turn the control until the lines disappear.
If the set does not have the access holes you can stil perform the adjustement, but you should make sure not to touch anything else as there is high voltage present and it could be very dangerous/Lethal to touch the wrong thing
Mar 12, 2009 | Sony KV-32TW67 TV
New LCD
What ever Sony is offering you, seems good for LCD. there is no easy repair solution for LCD Panel problem.
May 27, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony KV-30HS420 turns off all by itself
This is less a solution than a work-around, but it does work for me, and it is free or low-cost.
I have had the same problem on the same Sony (model KV-30HS420),picture fading out to green then black, then turning off by itself,after which sometimes the light blinks 6 times, other times it blinks 7times. This started about four years after I bought it, which is not adecent lifetime for a CRT TV. It would happen anytime from 2 or 3 timesan hour to 30 to 40 times an hour. After getting absolutely nowherewith Sony, which was completely unresponsive and unhelpful, and which refusedto stand by their product or provide any useful information, I wasgetting ready to buy a new LCD TV, any brand but Sony (never buyanything from them again), when on a whim I decided to try one last stopgap solution.
I put a fan up against the side of the TV, blowing into the vents. Ithas been 3 days now, and not once has the fading and shutting downoccurred. So it looks like the fading out and shutting down wassomehow related to heat, and the ventilation seems to have solved it. I don't know why it should be a problem now, when it was not the first fewyears. It is also a mystery why Sony has not been able to figure thisout, since it is clear from online postings that many people have thisproblem with this model. Give this a try and see if it solves theproblem for you.
Apr 07, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Television will not turn on
My Sony KV 32HV600 will not turn on, unless I take it for a car ride THen it will turn on and is fine until it shuts off again. Which circuit board should I change or send in for repairs? definately there is a loose contact as you have ezplained. please check connector or some print loose or parts loose in power supply. if it is ok then check h/output section for loose or print break. it is not a major problem &can fixed ar home. no need to change board remove board &check for print. it requires tech knowledge.
Oct 04, 2007 | Sony FD Trinitron KV-32HV600 32" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
