Question about Intel Motherboard
Msi 648 Max-V mainboard: 2 short beeps and after 8 short beeps
Msi 648 Max-V mainboard, when i push ON button: 2 short beeps and right after 8 short beeps. Thanks.
  • 4 Answers
It's probably the video card. Take it out, put it back in. If that doesn't solve, try another card, possibly in another slot (pci instead of agp...)
Did that help?
Posted on Jun 30, 2009
Yep, worked like a charm. I swapped the GPU from slot one to slot two, that did the trick
Posted on Mar 31, 2011
Boot problems
SOURCE:No boot No video on new built pc with a msi motherboard a55m-p33 amd, three beeps at start up.
Hello here is the homepage:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Driver&os=Win8%2064
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Tree beeps means you have a ram module failure, or not inserted correctly.
This mainboard uses DDR3 ram, up to 16 gb.
Try to start with only one module at the time.
Try also to check the manual:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Manual
Jan 14, 2014 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
What is the max memory for MSI G71-mv31013-J24motherboard
Hello enter the msi mainboard number here:
http://www.msi.com/service/download/
The number is printed in on the mainboard:
This is just an example.
Good luck
Mar 06, 2013 | MSI Computers & Internet
ASUS P4V800D-X AMI BIOS AMERICAN MEGATRENDS BEEP CODES
Hello here is some beep codes:
Beep CodeDescriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
My guess is you have a ram/memory module failure.
Try to renew the ram module.
The asus homepage is here:
http://support.asus.com/Download.aspx?SLanguage=en&m=p4v800d-x&p=1&os=
Here you can download a manual.
Please unzip the file when downloaded.
Your mainboard is using following type of ram:
Dual Channel Memory Architecture
4 x 184-pin DIMM Sockets support max. 4GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory
These module does not exist bigger than 1GB.
Oct 15, 2012 | ASUS Computers & Internet
Long beeps not booting up
problem....the beeps are beep beep beep beep..........contiues...........plus the computer will then not recieve signal????
May 25, 2011 | MSI K9VGM-V Motherboard
Please, may you tell to me what is ACER ASPIRE M1641 motherboard name ?
Re: Sata driver - ACER M1641 desktop PC « Reply #8 on: March 28, 2009, 04:26:23 PM » I have discovered the previously unknown model of the motherboard in this system. I have searched and searched and could not find it anywhere. With the actual model of the motherboard you can get supported drivers right from the manufacturer, the same way you could if you purchased a standard motherboard like asus or gigabyte.
I have determined this motherboard (at least my acer a1641-e1712a) is a MICROSTAR board. A link to a board with compatable drivers can be found http://www.msi.com/index.php?func=proddesc&prod_no=1499&maincat_no=1&cat2_no=170&cat3_no=2 .
The board is a MSI board using their mainboard search. My criteria went as follows...
Mainboard -> Intel Platform -> Socket 775 Chip -> Nvidia Chipset -> Nvidia MCP73 Chipset
That narrows your down to 8 or so mainboards, all of which use the same sata,audio and onboard video. My above link http://www.msi.com/index.php?func=proddesc&prod_no=1499&maincat_no=1&cat2_no=170&cat3_no=2 will take you to a board where you can get SATA, AUDIO and VIDEO DRIVERS.
Hope this helps guys!
It may be a MICROSTAR board. A link to a board with compatable drivers can be found http://www.msi.com/index.php?func=proddesc&prod_no=1499&maincat_no=1&cat2_no=170&cat3_no=2 .
Hope this helps!
Aug 08, 2010 | Acer Aspire M1641-U1521A PC Desktop
My board does not turn on and its beeping. Ive counted 7 beeps. i tried replacing the memory with known good ones but still the beeping persist.
MSI states that 7 beeps means "Virtual mode exception error "
Explanation: Virtual mode is one of the different modes that the processor can run in. The system is reporting an error when testing this mode.
Diagnosis: There is a problem related to the processor or motherboard. Note that this doesn't mean that the processor is necessarily dead, since the system won't boot at all with a dead processor.
Not knowing the price of either your processor or the board it is hard to say what to do for the best
Good luck
AMI Beep Code Deep Code Description 1 short DRAMS refresh failure 2 short Parity circuit failure 3 short Base 64k RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed AWARD Beep Code Deep Code Description 1 Long, 2 Short A video error has occurred and the BIOS cannot intialize the video screen to display any additional information
Jun 19, 2010 | MSI K9N6PGM2-V Motherboard
No sound for msi n1996 motherboard
maybe your sound card driver is not yet installed.
May 02, 2010 | MSI 648 Max-L (MS-6585-020) Motherboard
When I push the start button the fans rotate for a second or 2.
ANY BEEPING NOISES, ANY FLASHING COLORED LIGHT.
SOUNDS LIKE ALOT OF COMPONET ERRORS AND CONFLICK ISSUES AND EVERYONE HAS TO BE FIXED 1 ITEM AT A TIME YOU MAY GET LUCKY AND FIX ALL THE PROBLEMS IN 1 SOLUTION BUT I DONT THINK SO.
YOU ARE HAVING IRQ AND DMA ERRORS
RODGANDYSR
Mar 13, 2009 | MSI Matx G31 LGA775 DDR2 (G31M3F)...
Intel Motherboard Logo
661 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
