Question about Xerox DocuColor 12 Printer
Blue,black thick line and print is not so glossy
Their is black or blue line occurs left side of paper edge and also print is not so glossy
  • 23 Answers
I work on the doc 12 every day. first look at fuser web once out look at the metal roller in side the web slot make sure there is no build up..the large gray fuser rolls should be covered with oil coatting so make sure the oil is pumping.
Posted on Jul 18, 2009
Were can i find a rear right axle 1997 dodge ram 1500 at as cheap as you can get it
Posted on Jun 30, 2009
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
Have black lines on left side of paper after printing
Usually this is occurs when the drum needs to be changed.
Jun 05, 2012 | Dell 3100cn Laser Printer
Printer keeps jamming and when it does print the right side of the paper (on my right) is torn on edges. there is NO paper in anywhere that is stuck that could be keeping paper from printing correctly. ...
Hi, You must go to your printer's options and change your paper thickness options. This is a very common problem when you are printing in normal paper and the printer's options are set to "Glossy Paper" or any other. Make sure this options are concordant with the paper you are using. It's going to work.
Hope to help you.
Steelmith
Jun 20, 2011 | HP Officejet 6500 Wireless All-in-One...
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
EPSON 1280 SILVER INK JET PRINTER, Stopped printing on glossy
Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
Jun 15, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Ink on edges and sides of glossy prints
What I ended up doing is wrapping a piece of old sheet aroung my finger and put it into the far left side of the part, that is mentioned in the cleaning directions in my book,. under "cleaning the machine printer platen." After turning the machine off first, I got gobs of the waste ink (several times) doing it that way. Then I took the ink damaged glossy photo paper, and ran that through the printer with just a small image for printing. It seemed to not pick up any more ink on the edges. I hope this helps someone else.
Nov 12, 2008 | Brother MFC-5460CN All-In-One InkJet...
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Xerox DocuColor 12 Printer Logo
221 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
