Question about Microsoft Xbox 360 Console
Can not connect
I am using a wireless g through my usb port to get my internet and have a ethernet cable running to my xbox 360. I have tried for days and cannot get my console to go online. My signal to my computer is strong. I have also put in all the correct IP,DNS numbers. Need Help
  • 1,463 Answers
Re: Can not connect
Have you checkedyour firewall for it being blocked ?
Posted on Nov 08, 2007
0 characters
3 Points
I got a two day gold pass and a xbox 360 i also got tmobile broad band internet on my pc so how do i get started with xbox live without an adapter or do i need an adapter
Requires a Router/Switch
(2) ethernet cables
Using your PC as the main Internet Provider, connect one cable from the PC's ethernet jack to the WAN jack/port of a router. Next hook up your XBox to one of the wired 1-4 jacks/ports on the same router with the other ethernet cable.
Mar 09, 2011 | Microsoft Xbox 360 Console
Wireless adpater not working with xbox 360
i would find out if the 360 can use any adapter i am under the impresion that you can only connect a xbox 360 antena to the console.My solution is connect your modem ethernet cable to the 360 and the adapter to the PC/laptop you will have a wied 360 and wiless PC/Laptop
May 26, 2010 | Microsoft Xbox 360 Console
How to connect xbox to computer with ethernet cable and wireless internet
you can only basiclly cant with only one connection which is either through ethernet or wireless device that you have to buy from any supermarket it s not hard either way to set them up
but with ethernet you need to have the xbox close to the router
wireless connects to your xbox 360 throught the usb then basically scan for your router then put in the routers wep key or wpa psk key
May 15, 2010 | Microsoft Xbox 360 Console
I am trying to hook my 360 to the wireless internet in my house using a belkin brand wifi antenna hooked into the usb port on my xbox can you help or is this even possible?
I'm not sure if it will work, but if it will, here's the link to configure up your Xbox for wireless.
The Xbox brand adapter works basically the same, so I don't see why it wouldn't work, unless Microsoft specifically took measures to prevent this. You may also have some security settings on your router that are preventing connection. I personally prefer to connect via Ethernet cable to reduce lag potential, but, to each their own.
Mar 30, 2010 | Microsoft Xbox 360 Console
Cant connect to internet using internet stick
The internet stick you have would be a USB device which is not supported by Xbox 360, you can connect to Xbox 360 wirelessly or through a wired connection
One way of connecting wireless internet is through the ethernet cable to a laptop paired with your wireless router, or you would have to buy a Wi-Fi adapter for Xbox 360 which retails around $90.
Since Xbox 360 does not have a software like a PC, it is unable to recognize the USB internet stick you have as a internet connection, it may probably end up showing it up just as a USB device on the system settings menu on the Xbox 360 dashboard
Jan 22, 2010 | Microsoft Xbox 360 Console
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
Blackout in my house, Xbox 360 ethernet port broken!
All the message means is it can't find the internet, so your internet must have went down.. your systems should still be working fine. I don't know much about using usb for ethernet, but that sounds like it would work no problem.
Apr 04, 2009 | Microsoft Xbox 360 Console
Connecting xbox to the internet
no, you can only use a microsoft wireless network adapter to connect without an ethernet cable.
Mar 19, 2009 | Microsoft Xbox 360 Console
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Martin Murray
Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
