Question about Motorola Mobility RAZR V3
Location setting i have a motorola razor and i am trying to set the location setting for safety reasons and i am unable to find that said to go under tools then system setting, then location but i am unable to find anything.. Please help
    Problem Solver:
  • 7 Answers
Re: location setting
If your cell is carrier locked, and carries custom carrier firmware (software for the phone) then you probably don't have that option available to you. Flashing a custom firmware is the only way to get access to locked items (not for the beginner phone tinkerer.)
Posted on Jan 27, 2008
0 characters
3 Points
my mobile no. 8826637327,my handset motorokr z6. In my mobile airtel sim unresistered sim showing.
Jul 12, 2010 | Motorola Mobility RAZR V3
I try to charge my razor using my blackberry charger but it wont work it keeps saying "unable to charge" why?
from explanation this means that you are trying to charge your razor with another phone charger , it will not work out for them self because they are not compatible .
what you need to get your razor phone is the type of his own charger ,but if you can not fine it own charger then you will have to go the store together with your razor phone then will help in locating it own charger that will work for with out any damage on your phone
thank you and thanks for using fixya.
Apr 11, 2010 | Motorola Mobility RAZR V3
My motorola razor says unable to charge bought new battery cleaned out phone nothing works
in the settings menu,there is a place that has a charge time adjust.Turn it off so the charger will start charging the battery.This is a feature so you can set the phone to charge in minutes,if the bat is too dead,then it would need hrs charging.Thats why it cannot start.
Apr 02, 2010 | Motorola Mobility RAZR V3
Motorola Razor V3xx has frozen keys except on/off button
Take the battery out and set it under a hot laptop for a half hour.
Jun 12, 2009 | Motorola Mobility RAZR V3
Internet connection
first of all, you need to have a data plan. if you do, check with your service provider for the settings.
alternatively, under applications, check to see if you have a pre-installed program called motorola setup. i automatically retrieves the internet settings for your moto.
Apr 18, 2009 | Motorola Mobility RAZR2 V8 Cellular Phone
Motorola Razor v3 clock setting problem dilema
Disable the "Automatic update" feature and set the clock manually.
To do this go to Menu, settings, initial setup, time and date, Autoupdate>Off, then set the clock and date.
May 01, 2008 | Motorola Mobility RAZR V3
The camera on my motorola razor phone is locked
try changing your firmware at a phone shop or on the net
Mar 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Pairing Jabra BT135 with motorola L2
Your not doing anything wrong it usually means that the headset isn't capable with ur razr or you need to reset both of them and try it again. Hope this helps =)
Feb 25, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Still can't get pictures
try resetting your phone to its orig settings and try it again...
Oct 16, 2007 | Motorola Mobility RAZR V3
Wont send messages
You need to configure the mms and sms settings of your provider. Check with your service provider for guides.
Sep 20, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
