Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Craftsman Riding Mower burning oil
It began a month ago burning oil faster than we can keep it filled. We get alot of smoke when we start it now. Any suggestions? Thanks.
  • 218 Answers
Hi,,my name is Keith..and i hate to be the bearer of bad news..but im 99% sure you have broken a ring(s) on your piston..and 1% sure that you have a blown head gasket..i hope this will help..if not please write me back
Posted on Jul 02, 2009
Craftsman lawn mower smokes
Has the mower been tipped up? if so sump oil can travel through the breather and into the air filter soaking it in oil which then in turn burns and smokes, remove the air filter and see if is soaked in oil.
There are other reasons, engine over filled with oil, engine breather blocked, engine worn.
Jun 02, 2018 | Craftsman Garden
Lawn mower blowing smoke
You are burning oil. This usually is from a leaky gasket. Go to ebay and find kiddie boutiques. They sell the best quality cheapest new tecumseh gaskets
Sep 27, 2014 | Garden
Hi I have a Craftsman Lawn Mower 225 and i bought a 40w oil and put in it and it started leaking and ommiting huge white smoke. what should i do?
Hi Manny First thing is Drain all the oil back out. You have most certainly overfilled it. Try and get as much out as you can from the same place you filled it from. Leave it tilted back until it stops running and then put the mower level for half an hour. Check the oil level now and clean the spark plug and replace it. There will still be oil in the air filter due to over filling. Only put oil in one egg cup at a time until its below max on the dip stick. Run the mower for 20 minutes and burn the smoke off. It may smoke for a few times but thats ok.
Aug 24, 2013 | Craftsman 675 Torque 190cc 21" Briggs ...
Craftman 917.270.711
check to see if the oil smells like gas the needle valve in the carb doesn't seat and gas drains into the engine the oil gets thin and burns it fast
May 30, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I put too much oil in the mower over the past couple months. Two days ago the mower began steaming. I shut it down immediately. Today I did an oil change and cleaned the mower up but after I started it,...
If you already changed oil and it is at proper level on dip stick let it run for about 5 minutes to burn out any excess oil in cylinder, if it continues to smoke you probably blew a gasket or seal on engine.If that is the case you are looking at buying a new mower unless if it under warranty or you have a cheap mechanic.
Aug 30, 2011 | Toro Lawn Mower With Toro Power Tools
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftman Lawn mower continues to burn oil at a fast rate
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
Jun 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman Won't Start
i think i'd look for a new repairman - did you check the oil? maybe he didn't put any oil back in it! or maybe the carb float stuck and the crankcase is full of gas. lift the hood and look for burnt wires or at the deck for a burnt belt - try to turn the engine over by hand [the round center with the perforations]. does it click when you try the key? if, not, check the fuse. without knowing the area that the smoke came from it's hard to single out a cause
Jun 11, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a 1987 craftsman riding 17 horse mower. I
Sounds like the rings are worn and letting oil escape past them into the cylinder head. After all, it's been in service a long time. There are several options, including a rebuild with boring out the cylinder and put oversize rings in, buying a new engine and replacing the old one, or just buying a new mower.
Sirwriter
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My lawn mower is spewing white smoke.
I had one in the shop that someone got their gas and kerosene cans mixed up and put kerosene in their mower it still had a little gas in it so it started up but had alot of white smoke if its blue I would tell you ,you over filled oil ,.
May 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
1,752 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
