Question about Epson Stylus C88 InkJet Photo Printer
I can't find a paper jam
I am trying to print on my epson c88+ and it has the red light blinking that there is a paper jam in the printer. I can't find it HELP!!!!!!!
  • sandra_wood May 11, 2010
    what does the sensor look like and where is it located? I am having the same problem
    Problem Solver:
  • 7 Answers
There's a possibility the paper sensor is stuck up,check if there's piece of paper between the sensor.or the sensor is out of position.
Posted on Jul 01, 2009
Epson C88 shows red alternately blinking lights
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Feb 05, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson C88 will not print, is flashing both paper and ink lights
I think you need to reset the counter, you can either take it into a epson service centre & have them reset it, or download a programme online.
you just need to google it, just type in service reset C88 that should do the trick.
Nov 06, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 plus
Make sure that the head can move on the carriage bar as this indicates a head assembly lock or jam. Make sure all the paper paths are clear and there is no tiny piece of paper stuck. Power it back on. If this does not resolve then you will need a visit to the repair shop or buy a new printer which is probably cheaper!
Sep 11, 2009 | Epson Stylus C88 InkJet Photo Printer
I have an Epson C88 and when I tried to print an envelope it went partway in and got stuck. It was not far enough in that I could pull it on through so pulled it back. Now the ink light and the paper jam...
while you pulled the envelop away did the envelop come out intact, or did it get damaged, if it was not damaged, then just restart the printer, you issue should be fixed.
If the envelop was damaged its likely that there is a paper piece stuck iside, which is tough to remove if you are not an expert. in such scenarion seek professional help
Jul 17, 2009 | Epson Office Equipment & Supplies
My ink is jammed fro epson stylus c88.
i would download the ssc and try reseting your printer
Mar 03, 2009 | Epson Stylus C88 InkJet Photo Printer
Printer will not print
Which of the two red lights is on? If it's the red paper light, it simply thinks it's out of paper. Make sure your stack of paper is properly seated in the Automatic Sheet Feeder. If it is the red ink light, it means that during a print task (printing, head cleaning, ink charging), an empty cartridge was detected. Go through the cartridge replacement procedure as described in your User Manual. If you don't have one, see:
http://files.support.epson.com/htmldocs/sc88__/sc88__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
"Replacing an Ink Cartridge.
If this information doesn't answer your question, please post a new comment with more information on what you want.
If this information was a help, please rate it.
Jan 25, 2009 | Epson Stylus C88 InkJet Photo Printer
C88 Printer won't print
Just as a follow up to this one for anyone else who hits this problem...
You can service the printer and redirect the waste ink yourself using the guide and information provided from this guide which I wrote a couple of years back.
It applies equally to the C84 - C88 and D88 models and certainly requires a certain amount of technical skill and patience but not beyond the amateur with a LOT of patience :)
In terms of resetting the waste ink counter or "protection counter" which triggers the service required message you can't use the SSC utility but instead will need to source the official adjustment utility.
Getting the product serviced is an option but frankly it usually costs more than the printer was worth so you've nothing to lose by trying to fix it yourself.
Hope that helps
Oct 01, 2008 | Epson Stylus C88 InkJet Photo Printer
EPSON R230 PRINTER
ONCE PRINTE COMMAND IS GIVEN PAPER IS ROLLED IN AND THEN PAPER JAM RED LIGHT BLINKS. CAN NOT PRINT ANYTHING.BUT NOZZLE CHECK PRINT CAN BE PRINTED.
Jul 23, 2008 | Epson Stylus Photo R200 InkJet Printer
The printer jam red icon never stops blinkin
> turn off the printer
> check for obstructions / torn paper
> disconnect the printer from the computer
> turn the printer back on
> if issue still persists, the printer needs service, contact the vendor
Jan 02, 2008 | Epson Stylus C88 InkJet Photo Printer
Printer has red lights permanently on when powered up
if they were initially flashing fast there is a fatal error and a repair is needed, but always try a re install first. Go to printers and faxes folder and go to your Epson C88 printer icon, right click on it and select cancel all documents or prints, then select uninstall, to remove the printer. Uninstall driver from add/remove programmes, turn off and remove printer from usb port and restart pc. Install the drivers and software again from the cdrom and when prompted to connect printer, switch it on but connect to a different usb port if possible and allow windows to detect and install. If the lights are still steady red or flashing fast, then the printer is faulty.
May 26, 2007 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 InkJet Photo Printer Logo
387 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
