Cost of replacement of TX3N2 expansion valve - Heating & Cooling
    Sergeant:
  • 340 Answers
250- 350 depends on the area
Posted on Jun 30, 2009
Where is the expansion value located?
Here's a video from Scotty showing you how to replace your expansion valve,had mine replace not long ago,had Midas do mine. Replacing An Expansion Valve In Your Car ,hERE'S A NEW PART. Expansion Valve at AutoZone com Best Expansion Valve Parts for Cars Trucks...
Jul 26, 2015 | 2001 Hyundai Tiburon
Expansion Valve cost to replace
price varies,call the place you are taking it too
Apr 24, 2015 | 2006 Nissan 350Z Roadster
How to replace expansion valve on a 2005 rx8
1.) Discharge air conditioning.
2.) Remove dashboard
3.) Replace expansion valve.
ive never seen an expansion valve in an rx8 go.....
usually its the climate control head. The blend knob stops working...
May 18, 2014 | 1999 Mazda 626
Expansion Valve
Follow the a/c lines to the firewall. The part they are attached to is the expansion valve. Once the a/c system is evacuated the lines can be removed from the expansion valve. The expansion valve can then be removed from the EVAP core.
Jul 13, 2013 | 2004 Nissan Maxima
Where is the expansion valve located on the 2004 KIA Sedona
Kia Sedona expansion FRONT valve located under dash, behind glove box, fan and coil. Evacuate freon first. Disconnect Freon lines from firewall., Lay right front seat back to flat horizontal position and lay on top or totally remove the seat for easier working access. Remove under dash cover, fan, glove box, coil housing, remove coil mounting bolts, remove old expansion valve. (Inspect old valve, if debris inside, blow out coil before installing new valve. If visible debris best to consider replacing REAR expansion valve and DRIER/FILTER in front of radiator too and blow out all lines and coils while servicing.) Use compressor oil to lubricate "O" rings on new FRONT or REAR expansion valve, install valve bolts, reinstall coil bolts to FRONT firewall or REAR frame, reconnect freon lines to firewall in engine compartment. Evacuate AC system, install freon (35 1/2 ounces, nominal 3 pounds), check system for leaks, check for proper operation, enjoy.
Sep 12, 2012 | 2004 Kia Sedona
How much does it cost to replace a expansion valve on 2000 camry
I think It costs $45 plus to replace a expansion valve. Here you can find more quality expansive
valve http://www.carpartswarehouse.com/part/ac-expansion-valve.html
Aug 16, 2011 | 2000 Toyota Camry
The air conditioner has a leak in the passenger/ rear side. what has to be replaced and how much will it cost?
I just gave a customer an estimate on that the other say. You can easily expect $1,000 - $1,500 dollars to repair this. Usually one of two things happens. 1. The rear lines rot out, in which case the repair will be less. 2. What usually happens is the expansion valve rots out. The screws that hold the expansion valve to the EVAP core are usually seized so the EVAP core will also need to be replaced. Sometimes the lines can be reused and sometimes they can not. This would be the worst case scenario.
Jun 05, 2011 | 2005 Chrysler Town & Country
I am gone to put a new compressor on and somone recomended I change the expansion valve.Where is the a/c expansion valve locate and how do you change it?
It depends WHY its being replaced. If the compressor is destroyed and metal is in the lines, then the condenser should be flushed,and rubber lines replaced. It should be at the firewall where the lines connect to the evaporator. This is a job for a A?C shop. if you dont know what you are doing it can cost more.
Jul 01, 2010 | 2002 Dodge Stratus
99 Toyota Tacoma a/c reads high pressure on low pressure side
Does the compressor run?
Low side could be high without a running compressor.
A running compressor?
The expansion valve itself is about $50 and bolts in.
You will have to remove the 134a gas before installing a replacement expansion valve and vacuum the system before recharging.
Sep 07, 2009 | 1999 Toyota Tacoma PreRunner
Where is the expansion valve on a 95 Lexus es300 and from which direction does one access it in order to replace it? Just purchased new compressor, drier and expansion valve, no problem with the first two...
It is attached to the back wall of evaporator. You have to remove the glove compartment, blower unit and evaporator to get access to the expansion valve.
Jul 04, 2009 | 1995 Toyota Avalon
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
