Question about Car Audio & Video
Have kenwood kdc-x589 all hooked up and running amp control hooked up (pink/black wire) amp will not come on line amp is Kenwood 6202 400watt checked fuses etc there is power going to 25amp fuse in the amp what am i missing?
    Genius:
  • 1,550 Answers
Are you sure about the remote wire,because always be a light blue color( white strip) wire good luck
Posted on Jun 30, 2009
Need a stereo wiring diagram
Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
Feb 01, 2013 | Kenwood Sirius KDC-3025 CD Player
Trying to find a wiring diagram to install my kenwood kdc-mp342u into my 2001 grand am. any ideas?
Please let me know if you have any questions, and thanks for using FixYa.
2001 Pontiac Grand Am Car Audio Wiring Diagram kenwood kdc-mp342u
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: none
Run a wire to the fusebox for switched power. red
a 14 gauge wire will do--use a 15 amp fuse
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Gray (tape this wire off) none
Car Stereo Dimmer Wire: Brown (tape this wire off) none
Car Stereo Amp Trigger Wire: Pink blue
Left Front Speaker Positive Wire (+): Tan white
Left Front Speaker Negative Wire (-): Gray white/black
Right Front Speaker Positive Wire (+): Light Green gray
Right Front Speaker Negative Wire (-): Dark Green gray/black
Left Rear Speaker Positive Wire (+): Brown green
Left Rear Speaker Negative Wire (-): Yellow green/black
Right Rear Speaker Positive Wire (+): Dark Blue purple
Right Rear Speaker Negative Wire (-): Light Blue purple/black
Amplifier Mounted behind trim in the left side of the trunk.
May 19, 2011 | Kenwood Car Audio & Video
I forgot my code to Kenwood KDC X589. Is there a
Hi there Vern,
Your in Luck. I'm supplying a link to a tip posted by Robotek (one of our best) that specifically addresses Kenwood codes.
Click here for Roboteks Tip.
Best regards
Mike
Jul 29, 2010 | Kenwood KDC-MP528 CD Player
Which wire is my amp power wire on a kenwood kdc-x617
hey mate,
You will need to run independent power and ground wires for the amp, then run your RCA leads from your headunit to your amp, the trigger wire to turn your amp on and off with the headunit is the pink and black wire in the kenwood wiring harness...
Hope this helps
Brad:)
Sep 22, 2009 | Kenwood KDC-X617 CD Player
I want to change the clock on my Kenwood Excelon KDC-X589.
try in standby mode push the menu button scroll through with track button till you see clock adj if not in standby mode try it in cd mode same steps
Mar 15, 2009 | Kenwood KDC-X589 CD Player
Splicing the wiring from a kenwood excelon kdc-x589 unit to a jeep harness
For the Kenwood KDC-X589:
yellow - always on B+12 such as battery + terminal
red - switched B+12 such as ACC of IGN switch
black - body/chassis ground (- battery)
orange/white - dimmer control wire (car light control switch)
gold - to my knowldege no gold
brown - mute control from mobile phone
pink/blk - external amplifier control/trigger wire
blue/white - power control wire similar in function as the orange/white
blue/blk - to my knowldege no blue/blk
blue - motorized/power antenna
For the vehicle, pls postback info on year and make/model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 13, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Kenwood KDC-X589 seems like the CD player doesn't put out sound
you have to change the cd read setting it might got set to cd read 2 it needs to be cd read 1 in standby mode press menu button scroll through with track button till you see cd read and set it to cd read 1 if not in standby mode try in cd mode same steps
Jul 03, 2008 | Kenwood KDC-X589 CD Player
Kenwood cd player to an 05 jeep - no sound
Hook the Blue/white striped wire to the power antena lead of the jeep (blue) to turn on the factory amp
Don
Apr 17, 2008 | Kenwood KDC-135 CD Player
Kenwood Manual for KDC-X589
http://www.retrevo.com/support/Kenwood-KDC-X589-Car-Receivers-manual/id/479dj585/t/2/
There you go, i dont know if you already found it but there it is for anyone else as well.
Mar 21, 2008 | Kenwood KDC-X589 CD Player
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
